How to Use Button Module With SkiiiD
This project is an instruction of "how to use Buzzer HW-508(applicable for KY-006) with Arduino via skiiiD
Before start, below is a basic tutorial for how to use skiiiD
https://www.instructables.com/id/Getting-Started-With-SkiiiD-Editor/
Teacher Notes
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Search or Find a Component
① Type 'Button' on the search bar or find the Buzzer module on the list.
Step 5: Select Button
② Select Button Module
Step 6: Pin Indication and Configuration
then you can see ③ pin indication. (You can configure it.)
*This module has 3 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for Button Module] in case of Arduino UNO
Signal: 0
VCC: 5V
GND: GND
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of Button Module
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
isClicked() - This code shows 1 as clicked status, and 0 as unclicked status.
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and welcome to feedback. Below is contact methods
email: contact@skiiid.io
twitter: https://twitter.com/skiiiD_official
Facebook: https://www.facebook.com/enterphin
visit https://skiiid.io/contact/ and go to Need help tab.
Comments are fine too!
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
