How to Use Delta WPL Soft Simulator Software? (Beginners)
Introduction: How to Use Delta WPL Soft Simulator Software? (Beginners)
About: SMART THINKERS makes tutorials of software use in engineering cycle. It will help engineering student to learn software easily. https://www.youtube.com/channel/UCKxxw5aIytdDkdXBPMt39ng
Smart Thinkers will provide tutorials for those who wants to learn PLC programming using Delta PLC simulating by WPLSoft 2.41 Software.
Step 1: Install WPLSoft Simulator Version 2.41
Step 2: Make Project File
Step 3: Start Your Project
Step 4: Select NO (Normally Open Switch)
Step 5: Then Add NC (Normally Close) Switch
Step 6: Add Output Coil (Y0)
Step 7: Now Add TMR (Timer)
You can add TMR (timer) from F6 appilication instruction tool. Set (T0-T255) and value of K in seconds.
Step 8: Add CNT (Counter)
You can add CNT (counter) from F6 appilication instruction tool > Basic tools. Set (C0-C255) and value of K in how many counts you want.
Step 9: Start Simulator to RUN
Step 10: Then Write to PLC Button
Step 11: Then Run Button
Step 12: And Last Online Button
Step 13: Now Check Your Project
When X0 Sets ON, output Y0 will HIGH because of latching state due to X1.
Step 14: Check Timer and Counter
When X2 Sets ON, Timer start and will stop after 5 seconds and makes output Y1 HIGH. Timer will reset when you Set OFF X2.
When X3 Sets ON, Counter starts to count and will stop after 3 counts and makes output Y2 HIGH.
Step 15: Full Video of Tutorial
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Sounds useful! Thanks for sharing :)
    Smart Thinkers
    Smart Thinkers
    Reply 1 year ago
    Thank you for appreciation
