How to Use Switches and Timers in WPLSoft? | Examples (Beginners)
Introduction: How to Use Switches and Timers in WPLSoft? | Examples (Beginners)
About: SMART THINKERS makes tutorials of software use in engineering cycle. It will help engineering student to learn software easily. https://www.youtube.com/channel/UCKxxw5aIytdDkdXBPMt39ng
In this tutorial, we are showing how to use switches and timers in real time applications as an example for practise.
Step 1: Read the Given Tasks/exersices
After reading exersice or given tasks specify inputs and outputs and switches need to add in your ladder diagram.
Step 2: Create New File
If you don't know how to use Delta WPLSoft Simulator, you can watch our tutorial.
Step 3: Make Ladder Diagram of Exersice 1
INPUT: Start/Stop switches, Water detector sensor.
OUTPUT: Pumping motor.
Step 4: Check Ladder Diagram Using Simulator
When we 'Start', motor will not run until water detector sensor senses the water. If sensor senses water, motor will run and will run because of latching switch 'Motor'.
Step 5: Make Ladder Diagram of Exersice 2
INPUT: Start/Stop switch, Timers
OUTPUT: Forward direction, Reverse direction.
Step 6: Check Your Ladder Diagram Running Forward (10 Seconds)
When we 'Start (X0)', timer will start for 10 seconds after 10 seconds 'T0' will high and makes motor to run 'FORWARD' direction. 'STOP (X4) switch is there to stop motor at any instant.
Step 7: Check Your Ladder Diagram Running Reverse (10 Seconds)
When we 'Start (X1)', timer will start for 10 seconds after 10 seconds 'T1' will high and makes motor to run 'REVERSE' direction until X0 not press.'STOP (X4) switch is there to stop motor at any instant.
Step 8: Subscribe Our Youtube Channel (SMART THINKERS)
LIKE, Share, Subscribe and Comment us to get more videos.
https://www.youtube.com/channel/UCKxxw5aIytdDkdXBP...
Step 9: Watch Complete Tutorial
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Audio Challenge 2020
