How to Use a Smart Geiger
1,027
Introduction: How to Use a Smart Geiger
About: Hi! I am a student and amateur scientist who loves cool projects and neat gadgets. I have a wide range of interest when it comes to STEM and several interests elsewhere.
Hello. I would like to share with you a neat little gadget that I found, and show you how to use it.
It is called a Smart Geiger. It is a Geiger counter for detecting ionizing radiation (Gamma and X-ray), it is pocket-sized, and can go on your key chain. Need I say more?!
You can buy one for about $35. You will also need a smart phone so that you can download the app that goes with it, which is free.
Hopefully this will be helpful, because the producer's website is not in english.
Step 1: Setting Up
First, download the FT lab Smart Geiger app to you phone.
The Geiger tube itself plugs in to the audio jack on the phone. If you have an iPhone 7 or later, like me, you will want to use an adapter to attach the Geiger counter. It will work just the same.
Once the Geiger is attached, open the app. Do not be alarmed to see that it already has a 0.1 microsievert per hour reading. It simply automatically accounts for natural background radiation that is always present.
To set a time limit for how long you want to run tests on your Geiger counter, go to settings and you will see four time settings: "infinity" (for untimed tests), 3 minutes, 5 minutes, 10 minutes, and 30 minutes.
You are now ready to run tests with your Smart Geiger
Step 2: Collecting & Reading Data
After selecting your time limit, point the round "window" on the end of the Geiger directly at the thing/location you are testing for ionizing radiation.
Note: do not knock the Geiger against anything while it is taking measurements. This will make it count falsely.
Press the start button and let it run until the time is up. If it measured any radiation, you will see the three following values:
1. microSieverts per hour. This is inside the circle on the top. MicroSieverts are a unit of radiation dosage. If the circle is green, the radiation dosage levels are safe. If it is red, there is a potentially dangerous level of ionizing radiation in the area.
2. CPM, counts per minute.
3. number of counts.
In the above picture, the Geiger had been set to the 10 minute time limit, but paused after 21 seconds. The Geiger measured 32.33 microSieverts, 103 counts, and 206.0 CPM.
Step 3: Saving Data & History
If you take a reading and want to save the data, there are two things you can do.
1. Take a screenshot of your phone.
2. Go to "save" and name the test.
To access your saved data, go to "history" where every test you saved will be recorded along with the date, time, and memo (name).
It will have the dates/times/memo, CPM, count, microSieverts per hour, and the duration of the test listed in that order.
Pocket Sized Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    6 Discussions
    Enigmine
    Enigmine
    1 year ago
    You do not use the sensor correctly : you have to activate the airplane mode otherwise the radio waves emitted by your smartphone distort the data.
    PhilipL70
    PhilipL70
    Reply 5 months ago
    The web page does say to switch off wifi, so it’s worth testing that that does/doesn’t have an impact.
    C8theGr8
    C8theGr8
    Reply 1 year ago
    The sensor doesn't detect radio waves. Waves have to be high-frequency (x-ray/gamma) to be detected by the Geiger counter. Radio waves are low frequency.
    SHOE0007
    SHOE0007
    1 year ago
    Well, that intersting I have a portable pocket (Beta, gamma and x-ray) GC for 150 dollars that can go to 1000+ micro Sv an Hr and max 65,000 counts per minute. What the max range of x rays and gamma this device can handle?
    C8theGr8
    C8theGr8
    Reply 1 year ago
    I am not sure what the max reading is. However, because the interface is a smart phone app it's probably not limited in the same way and I would guess that it can go up to however high you need. I see in your picture that yours says "nuclear radiation detector." The smart Geiger will detect x-ray radiation that is not nuclear as well (that's what I did). For $35 (on amazon) it may be worth testing and comparing if you use yours a lot.
    SHOE0007
    SHOE0007
    Reply 1 year ago
    Yeah I may do that. Calbirate the two with gamma sources. Sounds like a cool idea.
