How to Waterproof Your Shoes
  • THIS WORKS ONLY FOR CANVAS SHOES
  • MAKE SURE SHOES ARE CLEAN BEFORE APPLICATION
    • If there is dirt present the wax will not adhere to the fabric of the shoe properly
    • Cleaning shoes after application is extremely difficult
  • MAKE SURE THE LACES HAVE BEEN REMOVED FROM THE SHOE
  • SOME ELECTRONIC APPLIANCES ARE NECESSARY
Teacher Notes
Step 1: Gather Your Supplies
  1. Taper Candles
    • 10 in. white candle stick
  2. ANY Canvas Shoe w/o laces
    • Converse, Vans, Keds, etc.
  3. Hair Dryer w/ high heat setting
  4. Paper Towels
  5. Old towel OR newspaper
Step 2: Prep Work Area
  • Place an old towel or newspaper down to prevent any messes throughout this process.
Step 3: Check the Shoe(s)
  • Make sure that the shoe is dry, clean, and the laces are removed.
Step 4: Prep the Shoe(s)
  • Tightly pack paper towels into the shoe for support.
Step 5: Remove Plastic From Candle
  • Remove the plastic from the candle before applying to the shoe
Step 6: Apply Wax to Shoe(s) WITH FORCE
  • “Color” the shoe with the candle stick
  • Apply forcefully
Step 7: Apply Until a White/Waxy Coat Appears
  • If there are still dark spots on the shoe then reapply the wax harder to those areas.
  • Make sure the ENTIRE shoe has a thick layer of wax.
Step 8: Set Hair Dryer to High Heat
  • If the hair dryer is on low heat then the wax will take longer to soak into the fabric.
Step 9: Apply Heat to the Shoe(s)
  • Wave the hair dryer back and forth along the entire shoe slowly.
Step 10: Apply Heat Until the Wax Disappears
  • If the wax appearance is still on the surface of the shoe, you haven't applied enough heat.
Step 11: Let Shoe(s) Cool Off
  • Let the shoe cool off for 1-2 minutes before performing the next step
Step 12: Test Your Results!
  • Slowly pour water on the shoe to test if the shoe is waterproof or not!
Step 13: Repeat IF NECESSARY
  • If the shoe is not waterproof, allow the shoe to dry.
    • Air-dry
    • Apply Heat with hair dryer
  • Repeat steps 2-9.
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    Penolopy Bulnick
    3 days ago
    I didn't know you could do this! Thanks for sharing :)
