How to Write a Check
All you need is a blank check and a pen.
Teacher Notes
Step 1:
Find the blank “date” line in the top right-hand corner.
Step 2:
Fill in the day’s date.
Step 3:
Find the blank “pay to the order of” line.
Step 4:
Fill in the name of the company or person whom the check is for.
Step 5:
Find the small blank box on the right of the check.
Step 6:
Fill in the full amount of the check in numbers.
Step 7:
Find the long blank line directly below the “pay to the order of” line.
Step 8:
Fill in the full amount of the check in words. Make sure that the written amount of the check is the same as the amount you wrote in the small box on the right.
Step 9:
Find the blank "memo" line.
Step 10:
Fill in the reason for writing the check.
Step 11:
Find the blank "signature" line on the bottom right-hand corner of the check.
Step 12:
Sign your name on the line.
Step 13:
Finish writing the check by double checking the completion of all the above steps.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    audreyobscura
    7 weeks ago
    Nice! If you used any stock images, you should cite where you copied them from.
