How to Delete Contacts on IPhone at Once
Now and then, you may need to delete a number of contacts on your iPhone. If you would like to turn your iPhone to someone else, you may need to delete all contacts on iPhone at once. Deleting multiple iPhone contacts or removing all iPhone contacts at the same time on the iPhone itself is a laborious task since Apple's software only lets you delete one contact at a time, which can be a tedious process if you have 100 names that are destined for oblivion.
However, there are ways to get around this with relative ease, and this article will show you how to do delete all contacts from iPhone or how to remove multiple contacts you selected at once. Keep reading! The following tutorials will help you solve the problems of deleting contacts on iPhone, iPhone 4, iPhone 4S, iPhone 5, iPhone 5S, iPhone 5C, iPhone 6, iPhone 6 plus, iPad, iPad Air, iPad Mini, and iPod.
Teacher Notes
Step 1: How to Delete IPhone Contacts at Once With Syncios IPhone Manager
With Syncios iPhone Transfer, you can simply delete all iPhone Contacts within 3 steps.
1、Download and install Syncios iPhone Transfer on your computer.
Please note that iTunes must already be installed on your computer for running Syncios correctly. But you do not have to run iTunes.
2、Connect your iPhone/iPad/iPod to computer with USB and launch Syncios.
3、As soon as an iDevice gets connected, you will be displayed with your device Information, then click Information tab on the left hand side vertical column..
4、You can select all contacts by clicking the empty box on the upper-left side and click Delete button to remove all iPhone contacts.
Or you can just simply check the multiple contacts and remove selected iPhone contacts by clicking Delete button.
Step 2: How to Delete All IPhone Contacts With ICloud
  1. Tap the Settings icon on your iPhone’s Home screen to launch the Settings app.
  2. Tap iCloud.
  3. Set the switch next to Contacts to OFF.
  4. Tap on the Delete from My iPhone.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
