Introduction: How to Embed a Video Into Instructables
About: Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others to learn …
It's super easy for Google video, Yahoo! video, Metacafe, Brightcove, Revver, Blip.tv, and YouTube!
Put the URL of the video into our Video function inside some square brackets like this:
[[Video(http://www.youtube.com/watch?v=woxc2eIedlM) ]]
The video will appear in the text section of your Instructable's step. You can adjust the size of the video by doing this:
[[Video(http://www.youtube.com/watch?v=woxc2eIedlM, {width:500, height:400} ) ]]
You can also use the tool bar above most text boxes. Click the video button and drop in the URL of the video. Use the URL that takes you to the actual page on the video site with your video, not any special "embed this" URL. We'll take care of all the processing!
**Check out step 2 to see how you can get the correct embed for Blip.tv - the process is a little less intuitive than with YouTube, but it's still pretty simple.**
Step 1: The Video
Here, I embedded the video from the 1D Accelerometer by intoon
Example:
[[Video(http://www.youtube.com/watch?v=woxc2eIedlM, {width:500, height:400})]]
Display:
And, here I embedded the video from the 3D chocolate printer by saul
UPDATE 5/14/07: Yahoo Video has changed, and is slightly less easy to embed.
To include a yahoo video, you'll need to compose a URL. This is done by taking the first part of the yahoo video URL
http://video.yahoo.com/video/play?vid=
and appending the vid, which is not the same vid found in the original URL. That will not function externally. To find the real vid, you need to copy out the embed code, found below the video. In this case, it looks like this
<embed src='http://us.i1.yimg.com/cosmos.bcst.yahoo.com/player/media/swf/FLVVideoSolo.swf'flashvars='id=598437&emailUrl=http%3A%2F%2Fvideo.yahoo.com%2Futil%2Fmail%3Fei%3DUTF-8%26vid%3D54937&imUrl=http%253A%252F%252Fvideo.yahoo.com%252Fvideo%252Fplay%253Fei%253DUTF-8%2526vid%253D54937&imTitle=Lego%2Bchocolate%2Bprinter&searchUrl=http://video.yahoo.com/video/search?p=&profileUrl=http://video.yahoo.com/video/profile?yid=&creatorValue=ZXJpY2p3aWxoZWxt&vid=54937' type='application/x-shockwave-flash' width='425' height='350'></embed>
The real vid is found after the text "flashvars='id=", or in this case 598437. Add that to the back of the URL to get:
http://video.yahoo.com/video/play?vid=598437
and then use the video embed like normal. In this case we have
[[Video(http://video.yahoo.com/video/play?vid=598437)]]
Here I embed some video from Google video
[[Video(http://video.google.com/videoplay?docid=-1300191479870868157&q=how+to+cut+wood, {width:400, height:300})]]
Here I embed aMetacafe video,
http://www.metacafe.com/watch/445498/robotic_beer_launching_refrigerator/
[[Video(http://www.metacafe.com/watch/445498/robotic_beer_launching_refrigerator, {width:400, height:300})]]
Embedding a video from Brightcove is really easy to do as well. You just take the link that Brightcove gives you when you click on "link directly to this video" and paste it into the input video bar on instructables.
Here is the link for the "Twilight Zone" Lighter Trick on InstructablesTV.
http://www.brightcove.com/title.jsp?title=494918786
If I put that same text into the video bar I get the following video:
Step 2: Embed a Video From Blip.tv
To embed a video from blip.tv, first upload a video to you blip account. Blip.tv automatically creates a flash version of any video you upload. The conversion can sometimes take a minute, so wait until it finishes or else you won't be able to embed the correct code.
Once you have a .flv version of your video available, click on the "share" button below your video. A windows will open up in the tab below. Select "MySpace" from "Where do you want to put the video."
Scroll down to where it says "Copy the HTML below to paste into MySpace".
The embed is the long line of text that starts immediately after the letters:
src="
Copy everything after the first quotation mark including, but not beyond the extension:
.flv
So Blip.tv gives you the entire embed of:
<embed wmode="transparent" src="http://blip.tv/scripts/flash/blipplayer.swf?autoStart=false&file=
http://blip.tv/file/get/InstructablesTV-CanKnifeOpen517.flv%3Fsource
%3D3" quality="high" width="320" height="240" name="movie"
type="application/x-shockwave-flash"pluginspage=
"http://www.macromedia.com/go/getflashplayer"></embed>
but the part that the instructable needs is only:
&file=http://blip.tv/file/get/InstructablesTV-CanKnifeOpen517.flv
If you paste that text into the video field on instructables, ie, this:
[[Video(http://blip.tv/scripts/flash/blipplayer.swf?autoStart=false&file=http://blip.tv/file/get/InstructablesTV-CanKnifeOpen517.flv, {width:320, height:240})]]
  • note, there should be no line breaks in the above code, so if you just copy & paste, make sure it is all on one line without any spaces.
you should get a nice flash version of the player and video like this.
Step 3: Embed a Video From Revver.com
Embedding a video from Revver requires a bit of URL hacking, but it's possible.
First, go to the the appropriate video page, and select "Grab Code". Then under format, choose "Flash Embed" and copy out the text that appears in the text box above.
In this case, we get:
<embed type="application/x-shockwave-flash"src="http://flash.revver.com/player/1.0/player.swf"pluginspage="http://www.macromedia.com/go/getflashplayer" scale="noScale" salign="TL"bgcolor="#000000" flashvars="mediaId=218941&affiliateId=0&allowFullScreen=true"allowfullscreen="true" height="392" width="480"></embed>
What we need to do from this is re-create an flash embedded url. So we'll take the link after "src", which is:
and append a question mark and the mediaId, which in this case is 218941, resulting in:
http://flash.revver.com/player/1.0/player.swf?mediaId=218941
Now we need to trick Instructables into thinking this is a flash video, so we'll take the link above, and ad a "&.swf" to it, resulting in:
http://flash.revver.com/player/1.0/player.swf?mediaId=218941&.swf
Then one can use our normal video dimensions, but I'd recommend Revver's default width and height, 480x392. The resulting code is:
[[Video(http://flash.revver.com/player/1.0/player.swf?mediaId=218941&.swf, {width:480, height:392})]]
Which can be seen below:
