How to Make a 10 Sided D&D Die (Not a True Platonic Solid)
17,549
13
18
Introduction: How to Make a 10 Sided D&D Die (Not a True Platonic Solid)
This is the 4th in the D&D dice, however, it is not truely a Platonic Solid.
I put it in so you can make a whole set of dice.
Like in most of the previous Platonic Solid/Dice Instructables we will start with a triangle.
Step 1: Materials
A new addition to our materials this time, a 30/60 drafting triangle.
Superglue
Ruler
Pencil
Cardstock
Scissors
Butter Knife
30/60 Drafting Triangle
Nail Polish Remover: Just incase you accidentally glue your fingers.
Step 2: Making Our Base Triangle (Step One)
1. Turn the paper in a Landscape position.
2. Measure and mark 6 cm and 3 cm from the left side on the top and bottom of the paper.
3.Connect the marks at top and bottom lightly.
4.Using the ruler measure 6 cm from the left hand corner on an angle until it touches the 3 cm mark.
5.Repeat the process from the other side. The marks should come to a point and make a perfect 6 cm isosceles triangle
6.Double check the measurements and make sure all 3 sides are exactly 6 cm.
7.Carefully cut the triangle out.
Step 3: Making the Base Side Shape
7. Place the triangle template against the previous cut mark to make an inverted triangle on the paper.
8. Use the template to draw another triangle directly on top of the one you just drew.
9. Cut out the diamond shape.
10. Lightly draw a line between the two horizontal points .
11. Lightly draw a line between the two vertical points.
12. Place the 30 Drafting Triangle along the midpoint lines and lightly draw in the 30 degree line up to the midpoint on both sides.
13. Cut the bottom portion just drawn off. You now have the Base Side Shape.
Step 4: Making the Top and Bottom Half of the D10
13. Using the template draw the base shape.
14. Draw another base shape using the long side of the previous shape as one long side on the the new shape.
15. Repeat the last step a total of 5 times. This should net you a hexagon divided into 6 equal pieces.
16. Cut the Hexagon out.
17. Cut one of the Base Shapes out of the Hexagon.
18. Make another Hexagon minus the Base Shape following the above steps.
Step 5: Joining the Top and Bottom of the D10.
19. Score the lines on each triangle.
20. Hold a ruler over the scored lines and gently lift the corner, this will allow a nice crisp bend in the paper.
21. Join the gap in one of the pentagons, using a tab and superglue.
22. Join each of the sides on the top to a side on the bottom.
23. Finish the D10 by closing the gap in the top penatagon.
Step 6: Paint
18. Paint, I used red for mine.
Now we have a D4,D6,D8 and D10.
The D20 is next.
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Halloween Contest
      Halloween Contest
    18 Discussions
    RichH44
    RichH44
    Question 1 year ago on Step 3
    step 7 is not clear to me. Keep in mind my job involves pattern development and laying out patterns.
    How do you get the bottom triangle?
    J_SCAP
    J_SCAP
    Reply 12 years ago on Introduction
    no decahedron have 20 sides this has 10
    cryophile
    cryophile
    11 years ago on Introduction
    Does anyone know how to carve these from wood?
    Eye Poker
    Eye Poker
    Reply 11 years ago on Introduction
    Cryophile, I'm thinking about revisitng this project this winter with a table saw and MDF.
    cryophile
    cryophile
    Awesome. I keep looking for instructions, but I can't find them. I plan on casting some dice from aluminum, and it would be nice if I had some solid wood dice to use as patterns so I didn't have to use real dice. They get expensive for little pieces of plastic.
    gregr
    gregr
    Why cant you just use the plastic dice for patterns? Or why not make a mold of a plastic die in silicone then cast wax into the silicone...
    lucek
    lucek
    the only hard part to making them out of wood is the chamfer ok a d6 is simply 45°. but the rest get more complicated.
    boozerker
    boozerker
    12 years ago on Step 2
    Can you add a pic for step 2 please?
    Eye Poker
    Eye Poker
    Reply 12 years ago on Step 2
    Unfortunately my camera has gone bye-bye. The idea is that you want to make a perfect 60-60-60 degree triangle or isosceles triangle that is 6cm on each side.
    nnygamer
    nnygamer
    13 years ago on Introduction
    Out of all the (A)DnD dice shapes this is the only one I never got around to making. Thanks for the plans! Can't wait to see your take on making a d20 (I did it in one piece not 20 separate triangles.) My sister had needed one for a charity cake walk type thing years ago.
    Eye Poker
    Eye Poker
    Reply 13 years ago on Introduction
    I made my D20 out of 3 seperate pieces. The top & bottom mirrors this instructable accept the angles meet at the apex portion of the hexagon. The middle is made out of a single piece folded 10 times. Came out pretty nice. That one will be next.
    Eye Poker
    Eye Poker
    Here is the template. A regular hex could be made with the equilateral triangles, but the folds in the 10 side need to be in the midpoint of the angles not the apex of the angles. Sorry thats as clear as I can say it.... Anyway, here is the template.
    lemonie
    lemonie
    I can't wait for number 5. L (can you add a template to this?)
