Introduction: How to Make a Pvc O and K
Materials for O
8- 90 degree side outlets
12- 6 in pipe
Step 1: Creating the Top and Bottom
first take 4 6in pipe and 4 90 degree side outlets
then connect two pieces of pipe into the sides of each outlet (not the top one)
You should now have a box
Repeat for the top of the 0
Step 2: Connecting the Top and Bottom Together
Put 4 6in pipes into the top outlet on the bottom part of the O
then Put the top onto those 4 pieces
And that is how you create a pvc pipe O
Step 3: Creating a Pvc K
materials
2- Tee Joints
3- 1 in pipe
2- 45 degree side outlets
2- 6 in pipe
2- 5 in pipe
Step 4: Making the First Part of the K
take 2 6 in pipe and connect it to the top and bottom of a Tee joint
Then take a 1 in pipe and place it into the Tee Joint
On the other side of the 1 in pipe add another Tee Joint
Step 5: Making the Rest of the K Part 1 of 2
on the Tee joint add a 1 in piece to both sides
Then place a 45 degree Side outlet on both 1 in pipes facing away from the Tee Joint
Step 6: Making the Rest of the K Part 2 of 2
Lastly place a 5 in pipe into the other side of both 45 degree side outlets.
Thats how to make a pvc K
