Hydro Dipped Hat
Introduction: Hydro Dipped Hat
I've been wanting to do this and I finally got the chance to hydro dip. I decided that if I'm going to hydro dip, I want it to be a piece of clothing so I chose a white baseball hat. I already did a practice one to make sure it works and it is actually very simple. In this instructable I'll teach you how to hydro dip.
Supplies:
  • The object that you will hydro dip(I'm using a hat)
  • Base color spray paint
  • Other colored spray paint
  • Tub or basket(No holes)
  • Water
  • Gloves(optional)
  • Tape and/or paper(also optional)
  • Scissors(if you using tape or paper)
  • Gas Mask(Recommended)
Teacher Notes
Step 1: Gather Your Materials
In order to hydro dip you will need to get-
  • Water
  • Gloves(optional)
Step 2: Add Spray Paint to the Water
Get your tub or bucket and add enough water in it so that your object will be able to be covered.
Put on your gas mask so that you don't breathe in all of the chemicals that the spray paint put in the air.
Grab your spray paint, I'm using one base color which is white and two other colored paints which are blue and purple, now spray the top of the water with the spray paint so that only the top of the water is covered in paint.
Step 3: Dip Your Object
Now that the top of the water is covered in paint, you can dip your object.
I recommend using gloves so that the paint doesn't get on your hands
Grab your object from the inside and dip it into the water, once you do that clear the paint rest of the paint to the side and pull your object out of the water.
Step 4: Wait
Now that you hydro dipped your object, put it on a towel or somewhere where it can dry.
It takes a while for it to dry so while this is happening you can clean up your materials and wait for your object to finish drying.
Once it is done drying, go show it off to your friends.
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
