Hypertufa Mushrooms or Tufarooms
3,238
52
9
About: I've been making art my whole life and work in many mediums .visit my Etsy shop.
First here is a definition
of Hypertufa.
Hypertufa From Wikipedia, the free encyclopedia
Hypertufa is an anthropic rock made from various aggregates bonded together using Portland cement.Hypertufa is intended as a manufactured substitute for natural tufa, which is a slowly precipitated limestone rock;being very porous, it is favorable for plant growth.Hypertufa is popular for making garden ornaments, pots and land forms. Hypertufa is relatively light compared with terracotta or traditional concrete and can withstand harsh winters, at least down to -30 °C (-22 °F). Hypertufa was invented for use in alpine gardens. Alpine gardeners formerly used antique animal watering troughs, which became rare and expensive.
I would also like to add making hypertufa can be fun and it can also be hot ,sweaty work.The temperature must be above 50 degrees for the cement to cure, so this is a warm weather project or moving you project into a heated building.
Teacher Notes
Step 1: Making Your Mold
In this Instructable we are going to learn about sand mold. in the first example I made a box out of plywood which has no top or bottom. I got a square of plywood larger then the box and put it on the bottom.I the put in a egg shaped piece of plastic ,large side down (from a microwave egg cooker). I then packed it with wet play sand which is fine.For these it doesn't matter but if your doing anything with some detail you'll want a fine sand. I then put a piece of plywood on top and flipped it upside down.The removed the mold and lined the impression with a plastic bag.I like using plastic bags because they wrinkle and leave texture.The second example is is
some plastic bowls and cups I found at the dollar store for 2 dollars. I got a plastic dish tray ,put a garbage bag over it and filled it with wet sand.Then I pressed in the bowls. Since the bowls where a little flat on the bottom I then found a ball and smuched it (Yes smuched is a word ) around. With the ball in the hole I then packed down the sand around the edges.I then line the holes with plastic bags.For the bases I use a variety of cups and cones lined with plastic bags.
Step 2: Mixing the Tufa
Mixing the Hypertufa
Supplies Portland cement type 1/2, peat moss, bag of sand,gloves. I prefer play sand but a medium sand will probably be stronger. I've been making tufa for over 25 years,anything from pots to large sculptures .There aremany different recipes out there but this is the one I always used. There are many that call for vermiculite and perlitewhich is fine but the sand gives it strength,although it also adds weight.The formula is 1 part cement ,1 part sand and 1 part peat moss. For larger sculpture you can add acrylic admix ,nylon fibers for extra strength and mesh and rebar frames .
I use a variety of cans to measure .I also write down what Iuse for future reference. For example 1 coffee can (1 each of materials) = 1 small mushroom and base.
I first mix the sand and peat moss together, picking out the pieces of stems and twigs out of the moss. Then I mix in the cement. It probably helps to wear a mask. Then make a well in the middle and add the water .Be careful not to add to much. Add some and mix and then add some more till you get the right consistency. You do not want it to wet !! Just enough so when you squeeze a handful it will hold its shape. you don't want water running out.The wetter it is the weaker it will be.
Step 3: Forming the Tufaroom
I then take a handful and press it into the bottom,about an inch thick. Then using a handful at a time ,I start going around the mold pressing the tufa together,using my thumb to press down on the edges. I then take a already finished base in a plastic bag and push it in the center .Then I run my fingers around the top and smooth it out.Then I fold the rest of the bag into the mold to seal it and let it sit for 12-15 hours or more till it's firm enough to handle. But be careful it's still fragile.
The large mushroom was done with a commercial mold.Started the same as the small ones but about a quarter of the way up the side ,a ball was placed in the mold and handfuls of the mix where place around and then tamped down with a piece of wood.
Step 4: Trim and Cure
Trim
Now gently pull up the bag so you don't upset the sand to much .I then smooth the edges using a big file with a rasp on one side or a small trowel. Be sure to clean file with wire brush. Then I wrap it up in the plastic bag and let it sit for at least week to cure. This is the minimum.The longer the better. Then take it out of the bag and it will take about a week to dry and turn light gray.I didn't feel like waiting tp weeks so the small Tufarooms in the photo are not dry yet.
Step 5: Large Sculpture Examples
These were made using rebar and a mesh they use for applying stucco to walls.The mesh is a pain to work with.
Stone Concrete and Cement Contest
Runner Up in the
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    9 Discussions
    dlarson3
    Question 4 weeks ago on Introduction
    Could this mixture be used to make stepping stones for a garden or is it not weight supporting?
    1 answer
    mnathan258dlarson3
    Reply 4 weeks ago
    Hi,You probably could . I've never tried it.But you'd probably be better off just getting a bag of concrete mix.you could try sprinkling some peat moss on the bottom of the mold before you pour if like that look. Let me know what happens .
    rachymarie
    6 weeks ago
    That's so cool, I wish I had these in my garden! I love mushrooms, eating them and the look of them (there are sooo many beautiful - and some ugly - species) and the Irish faerie ring lore. I am actually making a faerie mushroom costume for a Wearable Arts competition next year. But I digress (you've hit on a passion of mine) - I would love to try this
    Chimonger
    6 weeks ago
    Does this material encourage moss growth? Does it break up if clingy vines grow on or into it? (Think: “living wall” material)
    mnathan258Chimonger
    Reply 6 weeks ago
    Hi ,I don't know if it encourages or not.Thia pot I had sitting under bush for two years. Moss tends to like shade and moisture.You can also run moss through a blender with yogurt and paint it on.There's lot of recipes on the internet.Really haven't had any experience with vines.But tufa pretty tuff stuff. I've had some pieces for over 20 years . Good luck.
    Chimongermnathan258
    Reply 6 weeks ago
    Good to know! Might have to do the yogurt/moss trick! Help camouflage it faster!
    OutofPatience
    6 weeks ago
    I've been wanting to do some Tufa containers for my garden for ages...thank you so much for the recipe, photos, and clear instructions!
    Fo55ilise
    6 weeks ago
    We used Hypertufa at school to make an alpine garden from an old ceramic Belfast sink.
    I've always wanted the 'recipe' to enable me to make things for my garden, so a big 'Thank You' from me for this Instructable.
    rnjenny
    6 weeks ago on Step 5
    I would like to try this. nice instructible.
