Introduction: IJDMTOY LED Light Bar 05-07 Ford F-250 Install
The Ford F-250 is an amazing truck that is perfect for those needing to use their truck for work. This iJDMTOY Ford F-250 LED Light Bar for 2005-2007 models is perfect for those looking for a super bright LED Light bar and wants a simple installation. Requires no modifications and straight forward to install so lets begin.
Step 1:
First, take off the lower bumper garnish covers and also the center lower bumper cover.
Step 2:
Now, focus on the opening to the side. You'll see 2 bolts positioned vertically closest to the far ends of the truck. Remove the lower bolt.
Step 3:
You'll see the exposed opening from the original lower bolt and also an opening a few inches off to the side.
Step 4:
Get the metal mounting bracket and a screw. Thread the screw from behind through the opening in the lower bumper location as well as the mounting bracket. Bolt the components into place.
Step 5:
Bolt the ends of the metal mounting bracket back to the opening left by the original lower bolt from the F-250. Now use the original bolt to secure the ends of the bracket in place.
Repeat on the other side.
Step 6:
Bolt the LED light bar in between the metal mounting brackets and secure with screws, bolts, and washer.
Step 7:
Connect the wires to power up the Ford F-250 LED Light Bar.
Step 8:
As you can see this installation was straight forward and required no modifications. This iJDMTOY off road truck LED is a perfect upgrade and a must-have for owners of the 2005-2007 Ford F-250.
