IKEA Smart Lighting Hack - Nymåne With Sonoff (WiFi Switch)
About: I like smart home projects
Buy an IKEA NYMÅNE ceiling lamp -> insert a brain (smart WiFi switch) to make it smart.
Supplies:
IKEA Nymåne ($40), Sonoff basic ($5), nylon strip
Teacher Notes
Step 1: Insert the Sonoff Basic Between the Wire and the Wire Terminal
Insert a Sonoff basic between the wire and the wire terminal in the lamp. Fasten with a nylon strip. Fits perfectly and is invisible once the front diffuser is mounted.
TASMOTA firmware recommended: https://youtu.be/08_GBROKQH0
Step 2: Enjoy Being Able to Automate and Remote Control Your Lamp
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    2 Discussions
    audreyobscura
    Question 2 months ago
    Can you include some more info about the components you used and how they were installed?
    1 answer
    RuneG6audreyobscura
    Answer 2 months ago
    Sure. Happy you find it interesting. The only component apart from the lamp itself and the wire is the Sonoff basic WiFi switch (https://banggood.app.link/h87d2LoX3Z). The Sonoff has screw terminals and a clear marking of input and output as well as live wire and neutral wire, so there is really only one way to install it. The Sonoff is fastened to the lamp via a nylon strip. Hope this helps.
