IPad MacBook Pro Case
About: Making Stuff since the 80's
So this is my attempt at building a case for my iPad Pro using a MacBook Pro. I decided to do this as with the release of iPad OS Apple has finally managed to enable mouse support on the iPad
The early versions of the Intel MacBook Pro had a USB controller for the keyboard and mouse located under the trackpad. So you could turn them into a keyboard and mouse for a normal PC by connecting a USB lead. This made it an ideal candidate for the project that I’m going to do
I have to say for me this is the best keyboard that Apple made, much better than the current one on the MacBook that keeps breaking
Teacher Notes
Step 1: Parts
MacBook Pro A1150
USB C to USB A connector
Magnetic iPad case
iPad Pro
USB lead
Step 2: Take It Apart
First off is to take all the parts out of the case. It’s a simple as removing all the screws and pulling everything out of the case so it’s empty
If you need detailed instructions about taking it apart over to iFixit to check out there marvellous instructions about taking the MacBook apart.
Step 3: The MacBook Keyboard Conversion
The MacBook Pro Has a USB controller on the underside of the touchpad. You need to connect the red which is the power wire black ground wire the green wire and the white wire which the data wires to the pads on the bottom of the trackpad.
Check out the pictures that go with this step see where you need to solder the wires
This will enable you to use the keyboard and mouse on any computer and in this case you can plug-in to the iPad. This one to this will enable you to use the keyboard and any computer and in this case can plug-in to be at the iPad
Once it has been soldered onto the board and tested it it works I used a large amount of hot glue to secure everything in place and also insulated the connection
Step 4: Putting It Together
Now the keyboard has been all sorted and working
It all needs Putting together.
I have used black felt on the lid to cover the the back area then I glued the magnetic case. The iPad will then obviously magnetically attached to the back of the case
Next up is to threaded USB cable from the keyboard through the hinge where the display cable used to go. Do this I cut the cable and then re-soldered it back together when I pushed everything through covered it up with some heat shrink
and that should be it done. All that needs doing now is to turn on mouse support inside the accessibility settings of the iPad.
Step 5: Conclusion
so I’m quite pleased how this project turned out. It’s nice to the iPad in a laptop form factor keyboard section works really well I will need to quickly switch between apps.The mouse support isn’t as good as it’s slower than using the touch interface that you normally used using on the iPadOS
I don’t know how much all use the iPad in the case can see me using the keyboard section but not the mouse. I can see a lot of people going for this thinking it will replace that laptop when in fact the iPad would already replace your laptop that this case
what would be nice is to get a 12 inch PowerBook and turn that into an iPad case as the iPad would fit in there very nicely
Be the First to Share
    • Assistive Tech Contest
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
    audreyobscura
    5 weeks ago
    This is pretty great! I also had to come up with a clever solution to store my ipad, but yours is far more durable :P
