IRFZ44N Mosfet Amplifier
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make an audio amplifier using MOSFET IRFZ44N.This amplifier circuit will give good sound.
Let's get started,
Teacher Notes
Step 1: Take All Components As Shown Below
Components required -
(1.) MOSFET - IRFZ44N x1
(2.) aux cable x1
(3.) Speaker
(4.) Battery - 9V x1
(5.) Battery clipper x1
(6.) Capacitor - 16V 100uf
(7.) Resistor - 10K x1
Step 2: Mosfet IRFZ44N
This picture shows the output pins of this MOSFET.
Pin-1 - Gate
Pin-2 - Drain
Pin-3 - Source
Step 3: Solder 10K Resistor
Firstly we have to solder 10K resistor to Gate pin and Drain pin of the MOSFET as solder in the picture.
Step 4: Next Solder Capacitor
Next solder +ve pin of capacitor to the Gate pin of MOSFET as you can see in the picture.
Step 5: Next Connect Aux Cable Wire
Now we have to connect aux cable wire to the circuit.
Connect Left/Right (+ve) Wire of aux cable to -ve pin of capacitor and
Connect -ve (GND) wire of aux cable to Source pin of the MOSFET as you can see in the picture.
Step 6: Connect Speaker Wire
Now connect +ve wire of speaker to source pin of the MOSFET as solder in the picture.
Step 7: Connect Battery Wire
Next connect battery clipper wire to the circuit.
Solder +ve wire of battery clipper to the Drain pin of MOSFET and
-ve pin of battery clipper to -ve wire of speaker as you can see in the picture.
Step 8: Now Amplifier Circuit Is Ready
Now this MOSFET amplifier circuit is ready.
HOW TO USE IT -
Connect battery to the battery clipper and plug in aux cable to mobile phone/laptop/tab..... and play songs.
NOTE : If Amplifier is not working then change the polarity of battery.
Enjoy songs with full volume.
Have you any doubt about this project comment below now and don't forget to follow utsource.
Thank you
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
