Ice Marks
Skateboard Name: Ice Marks
Origin: from the extremely cold place, set beauty and speed in one, skateboard plane has a good anti-slip measures, can ensure that the friction between the skateboard and the foot is sufficient. At the same time, flanks on both sides allow the skateboard to have a better look on the slide. The wheels use a rotating circle to ensure greater flexibility for the skateboard.
Teacher Notes
Step 1: Step 1: First Select the Meta Capsule to Adjust It to Grow 224, Width 56, High 1.4
Step 2: Step 2: Decorative Base Plate Selection Diamond Mesh Size Length 95, Width 55, Thickness 1, Select the Base Plate and Diamond Mesh to Combine It Together
Step 3: Step 3: Select Snowflake and Star Name Adjustment Its Size Will Place Snowflake Sits in the Blanks of the Diamond Grid and Place the Star at Both Ends of the Base Plate So As to Enhance the Friction of the Skateboard to Prevent Slipping
Step 4: Step 4: Add Flanks at Both Ends of the Skate, Select the Adjustment Micro, Copy the Adjustment Micro, and Align It With the Floor Using Alignment. and Group the Whole
Step 5:
Step 6: Step 6: Connect the Soleplate With the Wheel and Allow the Wheel to Turn.Rotate the Ball to Connect It to the Middle of the Wheel and Secure It With Two Cylinders
Step 7: Step 7: the Wheel Is Fixed With the Soleplate to Make a Molding.
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
    2 Discussions
