Icosahedron Printed Joints Generator
Introduction: Icosahedron Printed Joints Generator
About: After a degree in micro-engineering in Switzerland, I moved to Russia to discover new landscapes
This is a FreeCAD script for generating versatile joints to assemble tubes in a icosahedron shape. Enter the inside and outside tube diameter and run the script.
I made an example with aluminium tubes. As the result is quite rigid I will use it as a support for a small table but an icosahedron can be used in many different ways. Show me what you did in the comments!
Teacher Notes
Step 1: Get the Parts
You need 30 tubes and 12 joints. I printed the joints and cut the tubes with a hacksaw at the same length (the length you want! It just has to be the same length). The tube I used were 9 cm length and had a 8 mm outside diameter (6 mm inside diameter).
Use freeCAD and the script to generate the suited joint for your tubes. I already wrote an instructables to explain how to use the scripts in FreeCAD here: https://www.instructables.com/id/Snow-Flake-Gener...
I had good results with a custom printing support. If you don't like it and want to make your own, just comment the corresponding lines (add # at the begging of the lines in the support section).
Step 2: Assemble the Parts
In the first three pictures I show how I clean the joins with only two cuts on each wall (still 120 cuts but it is not that long)
Then carefully assemble the tubes with the joints.
Be the First to Share
    • Finish It Already Speed Challenge
    • First Time Author Contest
    • Space Challenge
      Space Challenge
