Image Testing for Color and Clarity
Introduction: Image Testing for Color and Clarity
I made this Instructable for me; to improve my Instructables, however I intend to share what I found. I have noticed some of the images I upload to Instructabes come out perfect and other images loose clarity, a little discolored or fuzzy. Not knowing if it is my computer, the file formats, the internet, or the Instructables website that is causing the distortion, I decided to test my image file formats.
I make my schematics in Paint, not a circuit simulator program for two reasons. First, I like the looks of my schematics. Second, I design circuits that work in the real world, however many of my circuits don’t work in a circuit simulator.
I used just two images for this Instructable, however the two images are in seven different file formats.
Step 1: Bitmap
Although most of my schematics are black and white, I don’t use Monochrome because I like to color my LEDs.
These schematics are in order 16 Color Bitmap, 24-bit Bitmap, and 256 Color Bitmap.
If you look closely you can notice they are slightly fuzzy.
Step 2: Checking Image Clarity
I checked the image clarity by downloading the uploaded schematics and changing the white in the schematics to red.
As you can see in the first image (16 Color Bitmap) almost all of the white pixels turned red but the off white distorted pixels.
In the 24-bit Bitmap and the 256 Color Bitmap images there are much more off white pixels that didn’t turn red.
Not as good as the 16 Color Bitmap, the GIF or the JPEGs schematic most of the white pixels turned red but for pixels near the schematic, this is what gives the schematic a fuzzy appearance.
Step 3: Color Assembled Circuit Bitmap
These color assembled circuit bitmaps are in order; 16 Color Bitmap, 24-bit Bitmap, and 256 Color Bitmap.
The loss of color in 16 color bitmap makes it almost a monochrome image.
And 256 color bitmap is noticeably whited out most noticeably on the capacitor and the battery.
Here the 24-bit Bitmap is almost as good as the image I produced it on my computer.
Step 4: GIF
The color assembled circuit GIF image is distorted by whiting out most noticeable on the battery.
I checked the GIFs schematic image clarity by downloading the uploaded image and changing the white pixels in the schematics to red.
As you can see almost all of the white pixels turned red but for a very few distorted pixels
Step 5: JPEG
The color assembled circuit JPEG image is distorted by whiting out most noticeable on the battery.
I checked the JPEG schematic image clarity by downloading the uploaded image and changing the white pixels in the schematics to red.
Almost as good as the GIFs schematic most of the white pixels turned red but for a few distorted pixels near the lines in the schematic. These few off white pixels cause the fuzzy appearance.
Step 6: PNG
The color assembled circuit PNG image clarity is very good comparable to the 24-bit Bitmap and TIFF.
I checked the PNGs schematic image clarity by downloading the uploaded image and changing the white pixels in the schematics to red.
Not as good as the GIF or the JPEGs schematic most of the white pixels turned red but for pixels near the schematics lines, this is what gives the schematic a fuzzy appearance.
Step 7: TIFF
The color assembled circuit TIFF Image clarity is very good comparable to the 24-bit Bitmap and PNG.
I checked the TIFFs schematic image clarity by downloading the uploaded image and changing the white pixels in the schematics to red.
Not as good as the GIF or the JPEGs schematic most of the white pixels turned red but for even more pixels near the schematic, this is what gives the schematic a fuzzy appearance.
Step 8: Conclusion
Even though these are all the same images they are saved in different file formats. Not all file formats are equal and none of the file formats did both the schematics or the color assembled circuit with good quality.
I found the best uploaded color assembled circuit is the 24-bit bitmap being just slightly better than PNG and TIFF.
I found the best uploaded schematic the GIFs schematic being just slightly better than JPEGs and much better than the 16 Color Bitmap. Almost all of the white pixels in the GIF schematic turned red making it the least distorted schematic.
Colors of the Rainbow Contest
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    2 Discussions
    andrea biffi
    andrea biffi
    1 year ago
    I understand the need to compress images on the instructable page, anyway I agree with you that a better quality should be welcome, especially for diagrams. It happened that many people asked me to send bigger diagrams because they couldn't read numbers, nowadays some of them are used to have everything ready and they didn't click on the thumbnail to obtain the full res image.
    Josehf Murchison
    Josehf Murchison
    Reply 1 year ago
    I published this Instructable because I needed to publish it to check the images.
    I'm just a couple Instructables from 100 featured Instructables. If you check the featured Instruvtables check list it says good clear images.
    Doing this I found some file formats loose image quality at my computer.
    Other file formats loose image quality after up loading.
    However I did find 2 file formats that come out with almost perfect clarity.
    I don't know if it is image compression or data transfer through the internet but better images may bring me that much closer to my goal of 100 featured Instructables.
    And if other members at Instructables can use this experiment to make their Instructables better, great.
