Impossible Dovetail Novelty Gift Box
Introduction: Impossible Dovetail Novelty Gift Box
3D-printing and demonstration of an "Impossible Dovetail" based novelty gift box, which is designed to be more interesting and applicable as a novelty gift box rather than just a puzzle.
The Fusion360 and STL files are available at for free download:
http://www.fadstoobsessions.com/Downloads-Products...
The printing was done with PLA (although ABS, PETG etc would also be suitable). The instructions below detail the process of making and using the puzzle/gift box.
The following video demonstrates the whole process.
Video Index
00:04 Overview/Introduction
01:00 How I got the Idea/Why do this?
01:45 How the Puzzle works/solving
02:25 What's Different/Novelty Box rather than Puzzle Box
03:15 The Design/3D Printing
04:48 Physical Assembly
06:20 Final Testing/Demo
Step 1: Starting Instructions
All the necessary instructions, tips and tricks are detailed in the youtube video.
In overview, all that is required is to download the Fusion360 file, make any changes or modifications you desire, output the STL file, then using your favorite slicer software, generate the g-code and then print out the parts.
Step 2: Preparing 3D Printing File
The Impossible Dovetail Novelty Gift Box has been modeled using Fusion360. The necessary file is provided for free at the following web site
If you want to modify the size and or the wording, this is easily done via uploading the model into Fusion360.
The STL file for 3D printing is also exported from Fusion360 after you have made any desired changes.
With the STL file, then use your favorite slicer software and generate the g-code for your model of 3D printer.
Step 3: Physical Assembly
Once all the 3D parts have been printed, the dovetail joint pieces will require some light sanding (with a file or sand-paper - the grit will depend upon your material) to ensure a smooth, but tight fit.
Then install the magnet and the small metal rod (demonstrated in the video if you need further information).
The puzzle/gift box is now ready to go!
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
