Indoor Snowboard Trainer
750
7
7
About: I like snowboarding and guitar
Have you ever been dying to snowboard but then you realize it is still summer? With the Indoor Snowboard Trainer you can practice all year round!
Materials
  • A deck I used a spooner board but you can use an skateboard deck or any thing else you find that you can use.
  • Strong glue. I strongly recommend Goop Household glue because it is flexible and won't crack when bouncing
  • Old pair of shoes
  • Clamps (recommended)
  • Strong tape I used Gaffer Tape (optional, only use it you want to be able to remove shoes from board)
  • Bosu ball or trampoline (It is really fun even if you don't have either)
Teacher Notes
Step 1: Tape and Trace
Skip the tape part if you want it to be permanent. Put tape around the area that your shoes will be. Then put on the shoes, stand in a comfortable stance and have someone trace the shoes.
Step 2: Clean the Surfaces
Use alcohol wipes to clean both surfaces you are gluing. The board/tape and the shoe.
Step 3: Glue
Add glue to both the shoe and the board. If you do not have clamps wait 2-5 minuets until you stick the two together so it can dry a little to the surface (don't do if you are using a quick drying glue). If you have clamps stick the shoes to the board and put the claps on tight.
Step 4: Wait
Follow the instructions on the glue to find out how long to wait. If you are using Goop Glue wait 24 hour or longer if you want extra strength.
Step 5: Take of the Clamps and Get Reading to Ride
Once the glues has dried take off the clamps and put on the shoes.
Step 6: RIDE!!!!
Start jumping!!!!
Stick It! Contest
Stick It! Contest
Be the First to Share
    • Furniture Contest
      Furniture Contest
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
    7 Discussions
    LeaD18k8gr8
    Reply 1 year ago
    You're welcome!
    mlk123
    1 year ago
    Amazing and cool! I would like to see this done on a trampoline too!
    Katezach
    1 year ago on Step 6
    WOW! Such an awesome idea! Now any kid can enjoy learning snowboarding trick without a trip to the mountains.
    k8gr8seamster
    Reply 1 year ago
    Thanks. It is really fun! :)
