Introduction: Industrial Coat Rack Bench (Hall Tree)
One thing I learned making this entryway coat rack bench is that there's actually a name for it. It's called a hall tree. Who would of thought?
If you have a small entryway and are looking for a simple (yet cool) way to store your coats, shoes, hats, mitts, umbrellas and everything else, a hall tree is the ideal solution. I was inspired by a steel and reclaimed wood design I came across one day, so I recreated the look by using black paint for an industrial look.
You can watch the build video, or read on!
If you like the video please subscribe to my YouTube channel
Step 1: Tools & Materials
MATERIALS
- (3) 2 x 2 x 8 Select Pine Boards
- Reclaimed wood
- (3) coat hooks
- (36) 2-1/2" pocket hole screws
- (8) 1-1/4" pocket hole screws
- (10) 1-1/2" flat head screws
- (6) 1" flat head screws
- Spray paint
- Teak oil
TOOLS
Step 2: Build the 2x2 Frame
For this project I used three 2 by 2's. I started by making all my cuts as per the cut list below using my miter saw.
CUT LIST
- 2 @ 60" (back legs)
- 6 @ 10" (horizontal leg braces)
- 2 @ 27" (underside cross braces)
- 2 @ 6-3/4" (top shelf support)
- 2 @ 17-1/2" (front legs)
I laid all the pieces out as per the diagram so I could mark where to drill the pocket holes (blue arrows). I marked them on the underside or backside of the frame in order to make sure they wouldn’t be visible. I then used my Kreg Jig to drill all the holes.
Before assembling the pieces, I also made some pilot holes so I would be able to screw down the bench from underneath later on.
I proceeded to assemble each side of the frame using 2-1/2” pocket hole screws with the help of my Ridgid compact palm driver.
I finished off by lightly sanding the assembled frame, then applied 2 coats of matte black spray paint.
Step 3: Reclaimed Wood
CUT LIST
- 36" x 10" (bench seat)
- 36" x 6-3/4" (top shelf)
- 27" x 6-3/4" (coat rack)
Next I moved on to the reclaimed wood. Since I was using reclaimed tongue and groove barnwood, I started by cutting off the tongue from a few boards, then glued and clamped some pieces together to make a bench seat, a shelf and a coat rack. I then cut the pieces down to the final dimensions listed above.
I pre-drilled some pocket holes on the back side of the coat rack so it would be easy to assemble later on.
I sanded the wood with some 220-grit sandpaper, but only made light passes in order to conserve the wood's character. I finished it off by wiping on some teak oil.
Step 4: Assembly
Once the paint and teak oil had dried, I laid the 2 x 2 frames on their back to attach the horizontal seat support boards using the pre-drilled pocket holes.
I then screwed down the bench from underneath using the pilot holes I had pre-drilled while making the frame.
Next I moved on to the top shelf, but first clamped the coat rack into place. I made sure to center the shelf, then made small pilot holes before screwing down the shelf with some 1-1/2 inch screws.
I finally stood the hall tree up on its feet and screwed in the coat rack using the pre-drilled pocket holes.
Step 5: Finishing Touches
I finished off by attaching the 3 coat hooks to the rack using 1 inch screws.
If you haven't already done so, you can watch the step-by-step video
_________________________________________________________
For more fun DIY projects, visit my blog at diymontreal.com!
