Infrared Sensor + Fan to Blow the Flame Out
We are making a box with a sensor and a fan to blow out the fire that gets put in front of the sensor.
Arduino UNO
Diode
npn transistor
2.2 ohm resistor
Infrared sensor
dc motor
fan or propeller to put on dc motor
Teacher Notes
Step 1: Step 1: Set Up Your Arduino Board
Setup your arduino and wiring as following. It does not matter which pin you use for the motor as long as its a digital pin. It does not matter which pin you use for the sensor as long as it is an analog pin. Adjust your pins in the code accordingly or else your arduino will not run.
Step 2: Step 2: the Coding
Setup the code as following. I tried to explain everything as clear as possible in the comments of the code.
Step 3: Hooray, You Did It!
If everything has been wired properly and your code has uploaded to your Arduino UNO you can now blow out your candles!
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    DIY Hacks and How Tos
    9 months ago
    Fun design. I have actually made something very similar using an aquarium air pump.
