Introduction: Inspired Pearl Necklace Designs-a String and Pearl Charm Necklace for Girls
Make this creative charm necklace for girls in a few easy steps. An actually fantastic way to update the traditional pearl necklace designs as well as multiple the color to your spring and summer outfit!
Step 1: Work the First Sun Knot
1. Cut an fairy long red nylon thread;
2. Slide one pearl bead to the center. Then pass both two ends through one Tibetan bead;
3. Adjust the thread snugly and place the part on flat as picture shows;
4. Take the left end to form a loop, pass the tail under two vertical portions. Use the same end, work the second loop on right side, and pass the end under two vertical ones as well;
5. Take the unused right end, wrap the third loop, and then pass the tail through the loop 2 and loop 1, over and under as picture shows. Next go under the left end. Finally form the fourth loop and down through the loop2;
6. Pull the loop1 and loop3 firstly, and then the loop2 and loop4;
7. This is the first sun knot charm.
Step 2: Work the Next Sun Knot
1. Take either of the two working end, thread on one Tibetan bead and then one pearl bead;
2. Back thread the end through the Tibetan bead from top. Tighten the thread;
3. Align the two beaded charms and get ready to work the second sun knot;
4. Carefully adjust the thread to shorten the blank between two charms.
Step 3: Prepare the Rest Charms
Add beads and knot in same way.
For my pearl necklace designs, 5 pieces of this charm are required.
Step 4: Close the Necklace
1. Take two thread tails, cross them on your index finger;
2. Nip the right one and wrap 6 or more times along the finger;
3. Pass the end through the coils from left to right direction;
4. Take the coils off and adjust each of them gradually;
5. Since tighten both ends, left 7cm long at tail end adorn with another 2 pieces of pearl beads. Affix with overhand knot and secure by lighter.
Step 5: Thus Far, This Is My Charm Necklace for Girls!
While practicing the pearl necklace designs, the most difficult procedure is to adjust the thread for shortening the blank between each two sun knots. Accord to my perspective, just be calm down and keep the orders of each segment as original as possible. Whatever, hope you may love this exclusive charm necklace for girls.
