Install Xenon White LED Sidemarker Lamps on Porsche 911 Etc.
About: Everything about automotive LED lights
Let's learn how to install the Euro clear lens Porsche xenon white LED side marker lights. This installation will only take a few minutes on each side thanks to the direct replacement design. With an in-wire resistor decoder, you won't have to worry about any error messages popping up on your dashboard computer.
See if this LED side marker light set is compatible with your Porsche using the list below. If it is, let's begin!
  • 2005-2012 Porsche 911/997 Carrera (Carrera 4S, Carrera 4, GT, Turbo)
  • 2005-2012 Porsche Boxster 987
  • 2006-2012 Porsche Cayman
Teacher Notes
Step 1: Take Out Your Stock Side Markers.
Unplug the side marker light from its harness.
Step 2: Plug the Porsche LED Side Marker Light Into the Open Socket.
Step 3: Snap in the Clear Lens LED Sidemarker Lamp.
Before you do, you may test the xenon white side marker light to make sure it fully lights up.
Step 4: Repeat on the Other Side, and Enjoy!
Once you've confirmed that the LED side marker light works, repeat these steps on the other side.
Enjoy your Porsche's brand new clear lens xenon white LED side marker lights!
Find this and more OEM replacement LED lamps at store.ijdmtoy.com today!
Be the First to Share
    • Furniture Contest
      Furniture Contest
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
