Introduction: Instructions About Writing SQL Statements in SQL Server
The following instructions give step by step directions for how to walk you through writing basic SQL Statements in SQL Server. SQL Statements are used to work with databases whether it be retrieving or manipulating data. In order to retrieve and manipulate data you must learn how to get your hands dirty and understand how to write simple queries on the server. This simple instruction set aims to assist students or beginners for this tutorial and should take around ten minutes to complete.
We will be focusing on 4 primary areas for this tutorial: SELECT, WHERE, AND and ORDER BY commands. Each command is used to retrieve, add, modify or remove information from a table.
Step 1: Search
Search for Microsoft SQL Server Management Studio 18 in the windows search tab and click on it
Step 2: Login
Login with your correct Server credentials
Step 3: New Query
Now click on New Query in the upper left hand corner (see picture)
Step 4: SELECT Statement
Type “Select * From ‘Table_name’”, as shown in the picture, This statement is a syntax example of how to write a SELECT statement to select data from a database
Step 5: WHERE Statement
Type “Select * From ‘Table_Name’ Where ‘Condition’”, this creates the WHERE clause, which is used to filter records and used to extract records that fulfill a specified condition
Step 6: AND Statement
Type “Select * From ‘Table_Name’ Where ‘Condition’ and ‘condition’ and ‘condition’...” to combine the WHERE clause with the AND operator. It displays a record if all the conditions separated by AND are true.
Step 7: ORDER BY Statement
The ORDER BY keyword is used to sort the result-set in ascending or descending order
Step 8: Execute the Query
Press the execute button to run the query and execute the table
Step 9: Conclusion
Congratulations! You have now learned how to basic SQL Statements in SQL Server
This is how is an example of how the table should look like when running the query and executing the table
This instruction set has provided step by step guidance for writing basic SQL Statements in SQL Server. Enjoy the Querying!
