Insulated Dog House
1,709
6
7
Introduction: Insulated Dog House
For a project in school, I chose to build an insulated dog house, which can provide shelter for a dog during the harsh weathers of winter and autumn. I drew up several versions of what it can look like, until I decided that a simple, common dog house is the easiest to build, and the most fit for my goal. I was able to gather the wood, along with the screws and nails, from recycling places, such as my school, or my home. The rest of the materials, I got from a home-improvement store.
Dimensions:
Length: 100 cm
Height: 102 cm
Width: 60 cm
Teacher Notes
Step 1: Gather the Materials
For this dog house, I will be using two layers of wood for support on each side except for the door, and a layer of polystyrene for insulation in between each two layers of wood. At the end, I will paint the house with a specific type of lacquer to protect it against humidity, rain, or snow. At the end, I will also put a layer of polycarbonate on the roof, to help with resisting against humidity, rain, or snow. I used screws and nails to put the materials together, as they are easy to use, and resistant. Finally, I will be adding a layer of hay on the inside, as it is a great insulator, and soft enough for the dogs to like sleeping on it, while durable, and so it wont break when the dog gets in.
Step 2: Mark the Wood
Mark the wood with a pencil the dimensions of the dog house, and where the wood and polystyrene should be cut.
Step 3: Cut the Wood
Using a saw, cut the wood along the marked lines, and a normal knife can be used to cut the polystyrene.
Step 4: Put the Wood and the Polystyrene Together
Using screws, put the layer of polystyrene between the two layers of wood, for each side.
Step 5: Start Assembling the Dog House
After putting the materials together, you can start assembling the dog house, using nails and screws.
Step 6: Paint the Dog House
After the Dog House was assembled, start using the lacquer to paint it, and make it resistant against water. I opted for a dark lacquer, as it masks the uneven wood, and makes it look nicer.
Step 7: Add the Polycarbonate
First, bend the polycarbonate in half, and make sure you DO NOT cut it. After it is bent, place it on top of the house, and secure it in place using nails, as this reduces the risk of it snapping/cracking/breaking.
Be the First to Share
    • Indoor Plants Challenge
    • Trash to Treasure Contest
    • Sculpting Challenge
      Sculpting Challenge
    7 Discussions
    I wish that I was crafty enough to take on little projects like this in my home. Being me, I'd be lucky if I didn't staple my hands to the plywood or get myself sliced when I use the tools! Better to keep my drills and equipment in storage and leave all of this constructing to the professionals I reckon. Higher chance of the dog house staying upright and not falling on my pooch's head too! Haha!
    This would be great during the cold season should the pets need to be allowed outside occasionally. Some guests could be allergic or perhaps the place could be lacking of room.
    Ck9aTony
    Ck9aTony
    1 year ago
    Many articles for DIY dog houses recommend an antechamber, so that cold breezes can't just shoot into it. Combine that with a blanket and your insulation and you have one happy puppy!
    tirimies21
    tirimies21
    Reply 1 year ago
    Wow! That is such a great idea! Thank you very much, and I’ll make sure to build one next time I’m thinking of making a dog house!
    Ck9aTony
    Ck9aTony
    Reply 1 year ago
    Well, as you could see, not original to me. But a great idea nonetheless, especially when combined with insulation.
    Awesome. Far too many dog houses have little or no insulation. Dogs need some level of protection from the weather
    tirimies21
    tirimies21
    Reply 1 year ago
    Thank you very much! Means a lot to me that the project is actually useful and wasn’t done in vain! :)
