Intant Freeze Water!!!!
1,046
5
6
Introduction: Intant Freeze Water!!!!
find a empty bottle with a lid
Teacher Notes
Step 1: Fill the Bottle
fill the bottle with cold water from a tap don't fill all the way leave about 2 or 3 finger width apart
Step 2: Put the Lid On
put the lid on tight
Step 3: Put in the Freezer
put your bottle of water in the freezer for about 2h 30mins it has to be laid flat or it will not work close the fridge
Step 4: Done!!!!
take it out the freezer and hit it on a surface an the water will start to freeze!!!!!!!!!!!!!!!!!
Water Contest
Water Contest
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    6 Discussions
    buildandsewandstuff
    I once bought a bottle of water at a convenience store, and when I opened it, all the liquid water froze like a slushy instantly. I guess it's the same trick, but I don't understand why it works!
    Logixal
    Logixal
    Reply 1 year ago
    What's happening is the pressure in the bottle is dropping when you open it, which in turn lowers the temperature of the water. If the water is cold enough it will drop below freezing and freeze right away.
    Logixal
    Logixal
    Reply 1 year ago
    Its called supercooling
    m_tty
    m_tty
    Reply 1 year ago
    I don't know but it is a cool trick thanks
    m_tty
    m_tty
    Reply 1 year ago
    thanks
