Interactive Story Card
Introduction: Interactive Story Card
Do you want to make a storytelling card that interacts with a computer screen?
Note that Step 2 and Step 3 are done together. When I brought in the "Play sound" command, I recorded new sound, one command at a time.
Supplies:
  • cardstock
  • markers
  • metal fasteners
  • metal paper clips
  • copper tape
  • Makey Makey
  • Scratch account
  • Metal bracelet (Use a slap bracelet that is used as a party favor. Wrap it with aluminum foil)
Teacher Notes
Step 1: Story Writing
First, write your script. You will need the script when you record your story.
Step 2: Record Your Story
Record your story, one scene at a time. Name them recording 1, recording 2, in chronological order.
Step 3: Coding With Scratch
Code your story using scratch. If you would like to see the code for this story, go to https://scratch.mit.edu/projects/352028530.
Step 4: Marking the Key Stroke
Mark which scene corresponds to which keystroke. This is useful when you connect your story card to Makey Makey.
Step 5: Add Interactive Buttons
Insert a metal fastener from the front. Secure a metal paper clip with the fastener at the back, and then tape them over with copper tape.
Assembly
1. Insert Makey Makey in the USB port.
2. Connect the metal bracelet to the earth.
3. Connect the metal clips of your story card to Makey Makey.
Test
1. Wear the metal bracelet.
2. Touch each metal fastener button.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Makey Makey Contest
      Makey Makey Contest
    • Instrument Contest
      Instrument Contest
    seamster
    seamster
    6 weeks ago
    Nice little project, thank you for sharing!
