Introduction: Interface Raindrop Sensor to NodeMcu| for Beginner
in this tutorial you know about how to Interface raindrop sensor to NodeMcu
Step 1:
Today’s tutorial is about the interfacing of Raindrop sensor with NodeMcu. The rain sensor module is Vary easy tool for rain detection. It can be used as a switch when raindrop falls through the raining board and also for measuring rainfall intensity. The module features, a rain board and the control board that is separate for more convenience, power indicator LED and an adjustable sensitivity though a potentiometer.
Step 2: ​Working Principle of Raindrop Sensor
Raindrop sensor is basically a board on which nickel is coated in the form of lines. It works on the principal of resistance. When there is no rain drop on board. Resistance is high so we gets high voltage according to V=IR. When rain drop present it reduces the resistance because water is conductor of electricity and presence of water connects nickel lines in parallel so reduced resistance and reduced voltage drop across it.
Step 3: ​Pin Configuration Raindrop Sensor
It consists of two parts one is a black board with nickel layers on it and other is an integrated chip provided with some output pins.Board has 2 output pin and chip has 6 pin
Step 4: Circuit Diagram of Raindrop Sensor Interfacing With NodeMcu
The analog output is used in detection of drops in the amount of rainfall. Connected to 3,3V power supply, the LED will turn Off when induction board has no rain drop, and output is Low. When dropping a little amount water, output is High, the switch indicator will turn on. Brush off the water droplets, and when restored to the initial state, outputs high level.When no rain digital output is 1 and analog output gives 1023 max value. When rain is present digital output is 0 and analogue output is much less than 1023.
Step 5:
Code
Click Here
This tutorial first published
Click Here
