Interferometer of Michael Morley
Introduction: Interferometer of Michael Morley
The Michelson and Morley Interferometer was built at the end of the 19th century, with the main objective of characterizing the movements of the Earth from the perspective of the "Ether". LIGO (Laser Interferometer Gravitational - Observatory of Waves), with the objective of verifying the existence of the gravitational waves reported by the physicist Albert Einstein in 1916.
For the preparation of the interferometer, recyclable and low cost materials were used. Its main purpose was to detect, in a sensitive way, small displacements, vibrations and the refraction of the atmospheric air.
Teacher Notes
Step 1: Here We Go...
The following materials were used:
- Square pieces of wood.
- Threaded bar.
- Nuts and washers.
- Arduino laser 5v.
- Cell phone (to power the laser).
- Acrylic 6mm thick (effective beam splitter).
- Super glue.
- Pieces of mirrors.
At the outset, the wood was collected and served as part of the interferometer structure. One piece of acrylic was used as the beam splitter (650nm Laser), while two pieces of mirror were placed at 90 degrees to reflect the laser light deflected. About $ 5.15 was spent to assemble the equipment.
******* (For specifications and measurements please contact me via facebook - Caiotacão)*******
Step 2: Collecting the Data
The observed results were the annihilation and construction of waves caused by the phenomenon of light interference when subjected to minimum displacements and vibrations (palms, small noises).
It can be concluded that the low-cost Michelson and Morley interferometer proved to be very effective for analyzes involving small displacements, vibrations and refraction of atmospheric air, thus having a high sensitivity considering that it was created from easily obtainable materials.
New changes are being performed (decrease in size and better fit), what I can guarantee is that in the interiror of CD-ROM drive burners, there is a better quality beam splitter; new results will be demonstrated !!! see you later...
Step 3: References
BASSALO, J. M. F. A crônica da óptica clássica (parte III: 1801 – 1908).
Caderno Catarinense de Ensino de Física, p. 48-49, abr. 1989.
HALLIDAY, D.; RESNICK, R.; WALKER, J. Fundamentos de Física. Rio de Janeiro: Livros Técnicos e Científicos, 1996. v. 4, seção 39-4: polarização por reflexão.
CATELLI, F.; PAVAN, L.; BERNARDI, R. Medida do índice de refração de um gás com laser de diodo. In: CRICTE 99, 1999, UFSM, Santa Maria.
YOUNG, Hugh D.; FREEDMAN, Roger A. (2009). Física IV: ótica e física moderna. 4 12 ed. São Paulo: Addison Wesley. 100 páginas.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • First Time Author Contest
    2 Discussions
    baudeagle
    baudeagle
    Question 1 year ago on Step 2
    Interesting, how hard was it to align the mirrors? I would image that spacing the mirrors further apart affects the sensitivity.
    Does this have an application as a seismograph for detection of earthquakes? I read about this project
    https://grillo.io/openeew/
    Apparently, they want to make a network of sensors for advanced warning for earthquakes, I think that it might end up being something like this lightning detection network. http://en.blitzortung.org/live_lightning_maps.php
    Caio Felipe Tacão
    Caio Felipe Tacão
    Answer 1 year ago
    excellent question my dear!!!; aligning the mirrors was not so difficult, however ... a precaution must be taken, try to remember when assembling the equipment obeying the distances between the source and the beam splitter, and keep the same distances between the mirrors in relation to the beam splitter; you are right, when you increase the distance between the mirrors in relation to the most sensitive beam splitter becomes the equipment.
    sensors such as the LDR would serve to assemble the variance of the fringes generated by the interference, I believe that a direct liaison between the LDR and the audacity would serve for a primitive seismograph.
    good luck my dear!!!! XD
