Interlocking Plywood Laptop Riser - With Plans
6,361
95
21
About: Architect, Urban Designer, all-round tinkerer of odds and ends. Small solutions for big city living. Dreaming of lands faraway where garages are big enough to build a workshop in, or lakes are there for taki...
How do you clear up space on a limited desk? Build a laptop stand, also known as a riser.
This'll keep your laptop at a nice ergonomic height for ideal posture - no need to hunch over as you work. It also gives you space to store your laptop beneath, out of the way when you want to do some old fashioned writing with that antique technique of pen and paper.
Supplies:
Step 1: Version 1
After measuring the dimensions of my laptop base and keyboard, I realised that the top of the stand could be narrower than the bottom. So I designed it in AutoCAD as a splayed stand with angled legs.
These pieces nest into each other to save material.
I cut the pieces on a laser cutter out of 9mm plywood, with half lap slots. Note that the half laps are exactly half of the depth of the pieces, i.e. 12.5mm out of 25mm.
When laser cutting, you have to account for the kerf, or width of the laser beam, as you design. This is to make sure pieces fit tightly.
However I overcompensated, and the pieces needed some heavy hammering with a mallet to fit!
Step 2: Version 1 Destroyed
Eventually, the hammering did it in, and version 1 broke in several places.
So I decided to test the strength of this to destruction. It was pretty hardy, and didn't break under any household weights. Eventually I just stepped on it to break it in half.
Lesson learnt: the half lap joints effectively reduce the load-bearing members to just a paltry 12.5mm depth. Will change that!
Step 3: Design Version 2 - With Full Plans
So I hopped back on AutoCAD and amended the depth of the half-lap joints. You can see that the slots are now much shallower in the long 'leg' pieces, compared to the short 'cross' pieces. This is because the long leg pieces have to do all the hard work of spanning 480mm from end to end, whereas the short cross pieces only have to span 20mm (under an inch) between legs.
I also adjusted the width of the slots, to give a little more wiggle room.
I cut this out on the laser cutter again, although you could certainly print out plans and cut this on a band saw or scroll saw.
If anyone wants the plans, leave me a note. I'll need to clean up the AutoCAD to a presentable state before publishing.
UPDATE: I've added plans in DXF and PDF formats. The plans are at A1 size, with dimensions marked in mm. The slots are designed at 8.2mm, which fit perfectly for my 9mm plywood (the laser cut ends up closer to 9mm because of the kerf of the cut.) You may need to play with your own laser cutter offset settings to work for your particular machine's tolerances.
Step 4: Assemble and Finish
This time the assembly came together much easier, without too much abuse from the mallet.
I then left it outside (under shade) for a few days to let the charred smell wear off. The smell of laser cut plywood can be pretty acrid at first. Something about the burnt glue and wood soot that'll give you a bad trip.
Then I finished it with mineral oil, just wiped on with a rag.
Step 5: Plywood Waffle
Here's how the project looks with the oil finish. I like the contrast between the charred edges and the lighter wood faces.
The waffle top detail is also pretty interesting, but it's hidden beneath my laptop most of the time.
I'll have to apply this technique to a laser cut waffle stool or chair sometime!
Step 6: Works Great!
I think using this is pretty self explanatory. You can either use it just with a laptop, or with a laptop dock. The keyboard goes under the riser, and all the cords are out of the way at the back.
That's how it looks with my 17" laptop. Works perfectly!
I know some will say this isn't exactly woodworking... but I'll enter it in the woodworking contest anyway. I think the principles are the same, in designing for lap joints, etc. It's just the tools that are different!
Please vote if you liked it!
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    21 Discussions
    ERALPD
    2 days ago
    wow thats a great idea and looks so stylish.
    Thanks for your efford and sharing.
    AnandM54
    10 days ago
    Wow nice space saving project !!
    njwade
    Question 11 days ago on Step 3
    Thank you for offering and yes I would love to have a copy of the plan for the Plywood Laptop Riser. I can see this being a very useful item to have if you have limited space and so many other things I can think of.
    I use a scroll saw and, for me, would make an excellent project or gift.
    Thank you once again. njwade2010@gmail.com
    1 answer
    ucnnjwade
    Answer 10 days ago
    Thanks for the interest. I've just uploaded plans in DXF and PDF. Do share images if you build this!
    ucnjcrisman
    Reply 10 days ago
    ucnjcrisman
    Reply 13 days ago
    Sure. I'll upload it soon
    ArnoB14ucn
    Reply 10 days ago
    It would be great to have acces to the Autocad files.
    I want to make a 3D-printed version but i would have to use a dovetail connection on the leg pieces
    ucnArnoB14
    Reply 10 days ago
    cgriffieucn
    Reply 11 days ago
    It's a cool project. I'd love to see the plans too.
    ucncgriffie
    Reply 10 days ago
    ucnjcrisman
    Reply 13 days ago
    Wow I can imagine this would look really cool in clear acrylic!
    amy.fish
    10 days ago
    I would also love the file if you are still sharing. Very cool project!
    ucnamy.fish
    Reply 10 days ago
    4currans
    10 days ago
    Great design! Would love a copy for my laser students.
    ucn4currans
    Reply 10 days ago
    DavidH1126
    11 days ago
    If you were making a stool the legs would need to be more upright so that the major load on them was compression.
    ucnDavidH1126
    Reply 10 days ago
    Totally agree with you. Will work on that version one day!
    SylviaW37
    11 days ago on Step 6
    This just has to be one of the most brilliant designs I have seen for a long time. I'm trying to think who I can get to make one for me.
    terrefirma
    14 days ago on Step 6
    I like when makers discuss mistakes and changes they made. From the drawing I thought at first that you put wood across the top- edited.
    Looks nice though, but I think you still need some hardware.
