Intorduction to Skateboard Modeling
I built this skateboard model with the help of tinkercad, which is all free and provides enough resources for us students. This site is a great place to build models. My seniors gave me a lot of advice on how to build this model. I was very moved! I did not dye this model, it is left for the user to use.
Teacher Notes
Step 1:
Although
this model looks ordinary feeling, even a ittle awkward. In fact, it is not, including the use of structural stability andstrength of science, flow, man machine relations and many other disciplines of knowledge, built into the advanced skateboard!
Step 2:
Despite
do appearanceit sectuoly the originolshapeo the dragon boat You can 3c0 theends are45 degreeo up. which helps teduce the airesistance ndmokes the board faster. The middle plate c
Step 3:
Thee
are fcur wheela, plus tro bearings. formirgthe boticm structure of the skatcboard. The four whce 5 can provde enoughcontact orca for the skataboard.
The bearing USES an extremely stable structure, in which the transv
Step 4:
Board bottom, wheel, bearing and other parts are connected with screws, which is not only conducive to strengthen the integrity of the entire skateboard, but also convenient for maintenance and repair, which makes the service life of the skateboard greatly extended!
Step 5:
Step 6:
Intorduction
to skateboard modeling Chen yesheng. class 2 vehicle engineering class2019 This model is built with the tinkersad web page, this site has many advantages of easy to operate and free to use. 10%OKS Figure 1 is the modell built this time Although this model looks ordinary feeling, even a ittle awkward. In fact, it is not, including the use of structural stability andstrength of science, flow, man machine relations and many other disciplines of knowledge, built into the advanced skateboard! Figure 2is the botomo the boadtmade Despite do appearanceit sectuoly the originolshapeo the dragon boat You can 3c0 theends are45 degreeo up. which helps teduce the airesistance ndmokes the board faster. The middle plate c Stability of the foct.. Fipura3 thom the bearingn and whrela Thee are fcur wheela, plus tro bearings. formirgthe boticm structure of the skatcboard. The four whce 5 can provde enoughcontact orca for the skataboard. The bearing USES an extremely stable structure, in which the transv
Step 7:
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
