Introduction: Wooden Toy Racecar
About: Hello everyone! My name is Jolien, I'm 25 years old and I live in Belgium. I like to make stuff with my hands! This includes woodworking, painting, crafting,... Subscribe to my YouTube channel for more buil…
Hello everyone!
This wooden toy racecar was the first wooden toy I made a while ago!
Be sure to subscribe to my YouTube channel, so you don't miss out on my new videos!
https://www.youtube.com/user/Jolien2501
Step 1: Step 1: Prepping the Wood
For the racecar you'll need wooden blocks with these dimensions:
- 18.5cm long
- 4.2 cm high
- 4.5cm wide
Step 2: Step 2: Drilling a Lot of Holes
First let's drill 7mm holes for the wheel axles to go through.
After that put two racecar-blocks together and drill with a forstner bit an opening all the way through.
Now it's time to make the seat with a huge drill (two different depths).
Step 3: Step 3: Final Shaping for the Racecar
I transfered my pattern onto the wooden block and I'm trying to do my best to cut it out at the tablesaw. But you can use a scroll saw or a bandsaw for this.
Because I did the rough shaping on the tablesaw I have a lot of work with the rasp and the belt sander.
Sand the seat with the dremel tool. And finish the outside with some handsanding.
Step 4: Step 4: the Axles, Wheels and Finishing!
For the wheel axles you'll need a wooden dowel. But you can make one yourself if you start with 6mmx6mm and push it through a cutting die with your drill. And you'll end up with a 6mm dowel :). You'll only need to sand it smooth!
For the wheels I'm using 8mm thick wood and I'm using a 50mm holesaw. I'm sanding them with the help of my drill!
Glue on the wheels, with a washer in between. And you're ready!
