Invisible Broken Wire Detector
Introduction: Invisible Broken Wire Detector
About: Engaged in the electronic components industry for 5 years, it is also clear to see the headache of the industry. I am the creator of bomlist. Find the best way to save time and material.
Invisible Broken wire detector is an instrument, very useful under these circumstances since it can easily detect the location of internal snapping without contact and physical disturbance.When it senses the breakage in the faulty wire the LED in the instrument turns off, the user knows the location of the fault and the broken section of wire can be replaced easily.
This is the easy version of invisible broken wire detector.
Teacher Notes
Step 1: Prepare the Material
Only need:
3 x Transistor 9014
1 x LED
1 X Copper wire
Step 2: Connect According to the Circuit Diagram
Just connect them according the video, it's very easy.
Step 3: Complete the Invisible Broken Wire Detector
The circuit is made cheap and best. It would not only be able in reducing wastage of time but resources too.Thus using just a hex inverter and few resistors we are able to construct a device which can easily detect a faulty broken wire and thus save the extra cost of a user which is incurred on replacing it which is otherwise too difficult.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    2 Discussions
    Great intro to circuits project. Thanks for sharing.
    WOOTE
    WOOTE
    Reply 1 year ago
    Thanks.
