Magnetic Skateboard Wall Holder
About: Too much wood, too little time.
After seeing Genghis72's Instructable I had to make my own really. The only problem was, my skateboards were much much heavier.
Materials
  • Lots of screws (4x skateboard)
  • Anchors (3x skateboard)
  • A skateboard (1x skateboard)
  • Sandpaper ( up to 1000 grit)
  • Spray paint
  • 4 in PVC pipe
Teacher Notes
Step 1: Magnetic Wall Holders
I really liked genghis72's Magnetic Holders which he designed himself and after printing them I decided there was no reason to reinvent the wheel.
Finishing the Holder
  • Sand the parts down to a 1000 grit finish to get that sexy smooth polished look and then add in the magnets with epoxy or how you see fit.
Step 2: Line 'Em Up
Top Holder
  • Set the holders to whatever height you desire and screw them in using anchors. I placed all four of mine on studs to maximize strength.
Bottom Holder
  • Next grab a 4 inch PVC pipe and cut it every 3 inches.
  • Cut out a fourth of the circumference
  • With a heat gun bend one of the edges inward
Step 3: Bend Again
Using a heat gun and splint of wood bend back the lip so that you have a Lima bean looking shape
Repeat until all are bent in position.
Step 4: Screw It In
Spray paint a color that is not gold because I truly regret that decision and screw into the wall.
Tada, finished. Add and remove skateboards as pleased.
    • Indoor Lighting Contest
    • Metal Contest
      Metal Contest
    • Make It Fly Challenge
    3 Discussions
    Mannonj
    Question 2 months ago
    Hi there.
    Would you have any interest in (and availability to) make another one of these wall mount systems? These are quite impressive. If so, what would you charge?
    Thank you,
    Jack
