Iron on Sticker
Introduction: Iron on Sticker
Step 1: I created a Cricut Design Space profile on their website
Step 2: I designed a predetermined letter of the alphabet ( based off of Cricut Design fonts)
Step 3: I adjusted the size of the letter by unlocking the height vs width proportion by clicking the "lock", which unlocked the adjustments to where they could be made custom
Step 4: I then, customized the height and width of the letter to a size which I deemed appropriate
Step 5: Once the size was selected, the "make it" tab was selected
Step 6: From the "make it" tab, the option to "mirror" the image was selected, because the sticker made was an iron-on
Step 7: "continue" was clicked and the Cricut device (assuming the device is connected) was selected
Step 8: on the Cricut device, the setting Iron-on was selected
Step 9: a pre-sized cut-out of iron-on material was put onto a
Teacher Notes
Step 1:
Step 2:
Step 2: I designed a predetermined initial (using the Cricut design fonts)
Step 3:
Step 4:
The "make it" tab was then selected
Step 5:
Step 6:
"continue" was clicked and the Cricut device (assuming the device is connected) was selected from the drop down menu
Step 7:
Step 8:
a pre-sized piece of iron-on material was put onto the cutting mat
Step 9:
The mat was then slid into the guides of the Cricut and the button with the arrows was clicked (it lights up)
This pulled the mat under the blade
Step 10:
The "C" button was then clicked (this button blinked at this time as well) and this instructed the Cricut to cut the iron on material.
Step 11:
The button with the arrows was then clicked again to unload the mat.
Step 12:
Once the mat was unloaded, the iron-on material was then peeled off of the mat.
Step 13:
The white around the cutout was then peeled to leave the sticker on the transfer paper
Step 14:
The sticker is now ready to be ironed on to a cup, shirt, or other approved materials
I used a curling iron as the source of heat
Be the First to Share
    • Sew Fast Speed Challenge
    • Fandom Contest
      Fandom Contest
    • Jewelry Challenge
      Jewelry Challenge
