JAX I-Poster Base Assembly
Steps to run power and attach/detach base units
Supplies:
4 Metal Grommets (2 per end unit)
8 Pins (4 per joint)
Teacher Notes
Step 1: Power Can Be Run From Cord or Outlet Under Unit
Step 2: Power Runs Through Top, Then Use Grommet for Cord Management
Step 3: Assembly of I-Poster Base Step 1
Place 2 or 3 base units in install location in line with front doors all facing same direction.
Step 4: Assembly of I-Poster Base Step 2
Align units so end openings match up
Step 5: Assembly of I-Poster Base Step 3
Take supplied pins and insert in 3/8 holes which will align Base units so top heights match evenly
Step 6: Assembly of I-Poster Base Step 4
Next flip top and bottom latches to pull base units tightly together.
Step 7: Assembly of I-Poster Base Step 5
Base units should fit tightly together to present flat surface for I-Posters
Step 8: Disassembly of I-Poster Base
Unlatch top and bottom. Pull units carefully apart. Then push pins out with base units separated.
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
    Penolopy Bulnick
    16 days ago
    Nice job on your first Instructable! Thanks for sharing :)
