Introduction: KILLERK's Sniper in Pistol Form
This pistol has the power of KILLERK's sniper, but in pistol form. It shoots somewhere a long the lines of 30 ft with one rubberband. If any of ya'll find a mod for my pistol let me know and I might change the instructable.
Step 1: Making the Handle/trigger
For this, you will need a good eye. I didn't have enough time to take the trigger/handle apart so I just took pictures from different angles. Hope you can figure it out.
Step 2: Making the Barrel
Although this is the most time consuming part to build on my gun, it is the part that you need to make the gun work. Make two of pictures 3 and 4. THe first pic doesn't count.
Step 3: Putting the Gun Together
This is the money step. Well, this and the next step. this one is more important though. This shows the construction.
Step 4: Putting on the Rubberbands
This step is the easiest. what you do is first, you put the rubberbands around the orange and white seen below. than, you make the rubberbands get close enough together so they can go into the wheel and over. Lastly just load it like you would KILLERK's sniper. Just put one of those weird yellow-orange thingys ( I use beige ) on your white rod (lulz) and connect the rubberbands on to the beige piece and pull back the white till it gets locked on to the black miscellaneous piece. Pull the trigger. the only down fall to this gun is that instead of using the long black rod, you have two use the short white
Step 5: There You Have It
And there you have it. a pistol version of KILLERK's sniper rifle. I do recommend not to shoot yourself or others. Your parents would kill you. I would know. I've tryed. And don't be a knewb, when you can be an assassin.
