Jack Skellington String Lights
Introduction: Jack Skellington String Lights
With Christmas coming up I think it is time to decorate, these cute Jack Skellington string lights are perfect to put up anywhere in the house.
Supplies:
  • White ping pong balls
  • Black permanent marker
  • Hot glue gun with glue sticks
  • String lights aka Christmas lights (you can also use just a regular string if you do not want to use string lights)
  • Scissors or knife (only if you are using string lights)
Teacher Notes
Step 1: Creating Jack
To create these amazing Jack Skellington string lights you will start with the ping pong balls and your black marker; draw a Jack Skellington face on one ball and repeat until you have as many balls as you would like. Looking up Jack's faces is a great way to get some different ideas of his facial expressions. And don't worry about the face being perfect, Jack Skellington has never looked perfect.
Step 2: Using String Lights
If you are using string lights, you will need to cut a small x in the top of each ball. You will then push the string light through the x that you just cut. For extra security, you can hot glue the lights onto the balls.
Step 3: Using String
If you are using just a string, you will place some hot glue the string on top of the balls, make sure that each of the balls are evenly space out, I would suggest about two inches apart. Use as much string as you need.
Now you can hang up your amazing decorations around the house.
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Coffee Speed Challenge
    • Fix It Contest
      Fix It Contest
    Penolopy Bulnick
    Penolopy Bulnick
    2 months ago
    Nice job on these! I like the different faces :)
