3D Print Jack-o-Lantern Face Pieces - Mr. Pumpkin Head
3,349
About: Instructables Community Manager - I am powered by sugar and rainbows! For realz!
Every year, I like to get those little mini pumpkins because they are so cute. I'm never quite sure what to do with them (one year I stuck sequins in them) and as I was looking at them this year, I thought it would be fun to play with them like a Mr. Potato Head. So was born the Mr. Pumpkin Head!
I created a variety of eyes, noses, and mouths using Tinkercad to create 3D print interchangeable Jack-o-lantern face pieces. Though I did mostly traditional faces, I also threw in a couple of fun ones including a cat, an Instructables robot, and Minecraft Jack-o-Lantern face.
Etsy
You can get these Jack-o-lantern pieces (including the robot design) in my Etsy Store.
Teacher Notes
Step 1: Supplies
Supplies:
  • 3D Printer - I'm using a Prusa MK3
  • Filament
    • I'm using Glow in The Dark Blue (though it does glow in the dark, it isn't super bright and doesn't last long, just a warning if you are thinking of buying. I think green might work better than the blue but I don't know from experience), other colors could work well, but I recommend something that will contrast and stand out well from the pumpkin such as White or Black
    • I tried Gold but it blended in too well with the pumpkin, so I wouldn't recommend colors like gold, bronze, or copper
  • Mini Pumpkins
  • Measuring Cup, Hot water, glove/mitten and needle-nose pliers (optional) to bend pieces
Paint?
Don't have or want to invest in glow in the dark filament but still want it to glow in the dark? You could try to paint or spray paint. I got some paint but it was cheap and gloppy and did not work at all. I looked up spray paints but they all had pretty bad reviews. So, painting white pieces is an option but you may or may not have luck.
Step 2: Designs
These pieces were designed using Tinkercad and you can find the files on Tinkercad or you can download the whole bunch in this Instructable.
For the pieces I decided to make them 1.2mm thick, which is about 6 layers depending on your slicer.
I designed spikes to go on each piece and they are about 3.52mm by 3.52mm and 12.7mm tall. Whatever you do, the goal should be for them to be the same size as you'll be sticking them into the same hole on the pumpkin. I do have a couple with smaller spikes because of the design, but I didn't feel it could be helped (like for the X-X-X mouth).
Step 3: Unique Designs
I figured, while I was at it, I would try to create some fun non-traditional jack-o-lantern designs. These include Cat, Instructables Robot, and Minecraft Jack-o-Lantern.
Those were created mostly the same way as the previous except I tried to be more precise with the sizing on the Minecraft ones by using precise sized shapes and arranging them precisely.
For pieces that were meant to stick out the top or sides of the pumpkin, instead of doing the pyramid spike I did a triangular piece (as seen with robot antenna and cat ears).
Step 4: Print
Time to print!
I sliced and printed as normal, though I do slow my pieces down a bit. This is especially good for when you get to the tips of the spikes.
Step 5: Optional Bending
To help the pieces form a bit better to the pumpkins, you can curve the mouths.
To do this, heat up some water in the microwave until boiling. Take it out and let it cool a smidge so you don't burn yourself. (I used a measuring cup that I have specifically bought for non food items. PLA is food safe, but use your own judgement here.)
Carefully hold the mouth by the spike and lower just the mouth part in the water for a few seconds.
Pull it out and let the water drip off. Carefully push it into the palm of your hand wearing a glove or oven mitt. Remember to be careful. If thew water is still too hot you could burn yourself through the glove (I did once).
Give the mouth a slight bend. Don't go overboard as I did on some. You just want to help it along so it doesn't stick straight off the pumpkin like a mustache.
Do this for all the mouths only (and cat mouth and Instructable eye/eyebrow). I did do this for the Minecraft eyes but it was unnecessary and will undo it when I get a chance.
Step 6: Play!
Play around with your pumpkin pieces! Mix and match eyes and noses and even colors.
Step 7: Glow in the Dark
If you are using glow in the dark filament, put the pieces in sunlight or under a lamp (but apparently not LED, LEDs won't work). Let it sit for like 20 minutes and then if you take them to a dark room, watch them glow!
Halloween Contest 2019
This is an entry in the
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    11 Discussions
    attosa
    3 days ago
    Very cute! Will the glow in the dark glow brighter and longer if flashed with a UV light for a bit?
    Penolopy Bulnickattosa
    Reply 3 days ago
    Thank you :)
    The listing on Amazon for the specific filament I bought actually says "not uv light" so I don't think that will help with this one.
    As a side note, I went into my craft room at like 11pm one night and I could actually see the roll of filament faintly glowing even though it hadn't gotten any light at all for hours, so I thought that was interesting. So it can glow long if it gets enough light, but I still don't think you'll get a lot of bright time with it.
    ellygibson
    4 days ago
    This is such a great idea! I love the instructables robot pieces. Now I only wish my printer didn't need a replacement part. :/
    Penolopy Bulnickellygibson
    Reply 4 days ago
    Thank you! Yeah printers can be such a pain sometimes, I hope you're able to get it fixed up soon!
    gzumwalt
    6 days ago
    My wife just saw these, so I'm printing them now.
    Very nice!
    Greg
    gzumwaltPenolopy Bulnick
    Reply 5 days ago
    I recently received an Ultimaker S5 which came with black Ultimaker Tough PLA, so I used that. My wife purchased some tiny pumpkins and placed the first face on one.
    Very nice again!
    Greg
    punk chicken
    6 days ago
    I was thinking of doing this, but I got lazy and just used some stickers. Also my 3D printer hasn't been reliable. I'm thinking this would be a fun project for people with 3D printing pens. They could add thumb tacks to the top / back side.
    zakbobdop
    7 days ago
    This is adorable and a bit less messy that *bleh* pumpkin guts. Nice instructables pumpkin!
