Jason Voorhees's Belt
1,744
20
8
Introduction: Jason Voorhees's Belt
About: I'm a programmer from Siberia and the leatherworking is my hobby. I think the everyone deserves really high-quality goods and I'm trying to make them)
The most detailed instructions for the manufacture of three-layer belt: outer leather, inner leather lining, and a sling for durability and wear resistance.
This belt was made as a gift to a friend who is a fan of Jason Voorhees:)
A friend was delighted :)
Step 1: Prepare the Buckle
Choose a suitable buckle, not paying attention to the picture :)
In our case, Michael Jackson.
Using an awl or any other sharp tool, peel off the picture. Bye Michael!
Step 2: Make a Template Insert for Buckles
With the help of masking tape we glue the buckle, we will rub the contour with a handle and carefully cut out the inside.
Step 3: Make a Blank Insert of Leather
We paste the turned out template from an adhesive tape from a reverse side on a piece of skin of vegetable tanning.
Well pushed with a bone stylus, outlined with a pen and carefully cut out with a sharp knife.
Step 4: Mark Seam Line
With the help of a groover, we mark the edges of the edge and the seam line.
Step 5: Wet and Wait Until Soaked
Then we wet the surface well, so that the embossing pattern would easily lie down and hold tight to the skin. We are waiting until soaked.
Step 6: Move the Picture
Choose a picture and print it at the desired scale to the size of the buckle. We combine the edges of the leather buckle and the paper contour, glue the back side of the workpiece with adhesive tape so that nothing moves.
Then we gently use a non-sharp (!) Awl to trace the main outlines of the pattern on paper so that it is slightly pressed on the skin.
Step 7: Create Volume
By means of a rotary knife and and stamps we create volume.
The photos show the sequence: first, we cut (not through) the outline of the image, then drop one of the sides of the cut, then add details, and finally, carefully and evenly fill in the remaining background.
Step 8: To Color
After the embossing is well dried, you can paint.
Ordinary acrylic paints and thin brushes neatly paint the image, adjusting with a needle and thin sticks.
Step 9: Polish the Edges
Use the slicker to polish the edges. If you do not have a special tool, you can process the edges with a medium-hard nail file and then polish it with the soft side.
Step 10: Cut Belt Strip
We measure the base of the buckle, choose the skin of a suitable size.
We are using a special knife for belts, cut out the base, but in its absence, you can cut the belt with a very sharp knife.
Carefully trim the tip of the belt to the desired shape.
Step 11: Mark Seam Line and Trim Edge
With the help of a groover, mark the line, trim the edge with a beveler and remove the chamfer for a more neat shape.
Step 12: To Thin Skin
Thin skin with a special plane for the skin.
Since the belt is multi-layered, for convenience, the thickness of the upper skin should be reduced.
Step 13: Glue the Sling
To strengthen the belt and give the internal volume, glue in the sling inside, leaving approximately at the edges.
The place where the belt will be bent is already glued in the bent state.
Step 14: Glue Pad
Leather belt with a sling sticking to the lining.
The lining remains untreated, it allows the skin to breathe, absorb sweat and not paint clothes.
Step 15: Trim Excess Pad on All Parts
Carefully trim the excess lining on all parts: on the basis of the belt and loops.
Step 16: Protect the Masking Tape Lining (optional)
We glue masking tape on the lining for a while in order to protect it from paint, wax and anything else.
Step 17: Refresh Color
We update the color by painting, for example, paint for shoes, after which we remove the masking tape, we will not need it anymore.
Step 18: Trim Edges
Nail file gently grind the edges of the belt.
Step 19: Punch Holes for Seams
With the help of horizontal punches and hammer punch holes in the belt and loops.
Step 20: Thinner Inner Edge
Thin with a knife the inner edge of the belt and loops.
Step 21: Color the Edges
To color the edges of the loops and at the beginning of the belt, since after stitching the belt it will be difficult to process them
Step 22: Prepare Holes for the Seam on the Buckle
Punch holes in the leather insert.
Using a screwdriver or drill, drill the same holes in the metal base for the buckle.
Step 23: Varnish the Insert
Treat the leather insert with yacht varnish to increase durability.
Step 24: Flash Loop
Sew a needle, loop and fasten the nodules with a lighter.
Step 25: Stitch Belt
Thread the belt edge into the buckle and glue it to the base, thus securing the buckle.
Stitch the belt along the entire length, fasten the knots for strength with a lighter or a soldering iron.
Step 26: Sew in the Buckle
Sew a leather insert inside the metal base.
Step 27: Process the Edges of the Belt
Sand the edges of the belt and paint them completely.
Step 28: Mark and Punch Holes in the Belt
Mark the holes with the awl and punch to punch holes in the belt. If necessary, make a slot with a sharp knife.
Step 29: Wax Polish
Polish the finished belt with wax.
Step 30: Done)
Profit! Your beautiful masterpiece is ready!
Leather Challenge
Second Prize in the
Leather Challenge
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    8 Discussions
    dbake5206
    dbake5206
    1 year ago
    very nice!!! Good job. Can you tell me what weight and type of leather you used for the inner and outer belt pieces? thanks
    Ivan Beldiagin
    Ivan Beldiagin
    Reply 1 year ago
    Many thanks)
    I've used:
    for outer - solid balck chrome-tanned leather about 4mm before splitting and about 1.3mm after splitting
    for inner - soft neutral chrome-tanned leather about 1.5mm, but vegetable-tanned could be better
    for buckle - vegetable-tanned leather 3mm
    Texas_Mike
    Texas_Mike
    1 year ago
    Very Cool - Thanks for going into detail. Seeing how it's done is inspiring to fellow creators. Look forward to seeing more. Good luck in the finals.
    Ivan Beldiagin
    Ivan Beldiagin
    Reply 1 year ago
    Thanks a lot) I hope it's useful) and I will try to win)))
    hoozdman
    hoozdman
    1 year ago
    so cool, congrats
    jessyratfink
    jessyratfink
    1 year ago
    Dang that came out sharp! Looks fantastic :D
    Ivan Beldiagin
    Ivan Beldiagin
    Reply 1 year ago
    Thanks a lot, I hope this instructable will be helpful for someone)
