Java Hello World in Eclipse
Introduction: Java Hello World in Eclipse
Here we will be assuming you already have the Eclise IDE.
Teacher Notes
Step 1: Create the Project
After you have opened Eclipse select file -> new -> Java Project. Once you select that, you will see something similar to the below picture show up.
Step 2: Name Your Project
Now that you have created the project, you have a chance to name it. Feel free to name it what you will.
Step 3: Create a New Package
Expand the package and right click on the src icon and make a new package. In here is where you will be putting the class.
Step 4: Create the Class
After you have made the project you will want to right click that project and navigate to make a new class. After that a window, similar to the one below, will open up. Select the option to have a main method made for you. What this will do once you hit finish is make a .java class that you can then begin to edit.
Step 5: Create a Variable
Just below public static void enter the following String statement = "Hello World"; What this does is create a variable of type String. What it currently has is Hello World in it, which can be altered as you wish.
Step 6: Enter the Statement
Just below public static void enter the following System.out.println();
Step 7: Enter the Variable
Get inside the parentheses and put statement. This will cause the program to print what is in the variable when you run it.
Step 8: Run the Program
Click the save icon and then the icon with the green circle with the play icon in it.
Step 9: Congratulations!
You just wrote and ran a Java program. Feel free to smile a little.
Step 10: Experiment
Now experiment with the print statement. A couple of fun variants you can use are print and printf in place of println.
Be the First to Share
    • After School Challenge
    • Makey Makey Contest
      Makey Makey Contest
    • Raspberry Pi Contest 2020
