Introduction: Jeep Compass Switchback LED DRL Turn Signals Install Guide
This is an installation guide on how to install the high powered xenon white/amber yellow switchback LED daytime running light/turn signal lamps, made to fit the 2017 and later Jeep Compass. This set heightens your Compass's front end headlight aesthetic level as a solid LED bar by replacing the OEM turn signal lamps.
Step 1: Remove the Front Bumper As Well As the Front Turn Signal Lights.
Step 2: Unplug the Turn Signal and Daytime Running Light Harnesses.
Step 3: Replace the OEM Turn Signal Light Unit With the Switchback LED DRL Turn Signal Lamps.
Plug the DRL and turn signal harnesses into the new LED daytime running light turn signal lights.
Step 4: Final Steps
Mount the LED DRL turn signal lamp back into the fog light location.
Test each unit to make sure switchback function works as it should. Once you've confirmed that they work, remount your front bumper to finish.
Enjoy your Jeep Compass's brand new set of LED daytime running light turn signal lights!
You can find this and more OEM fit LED daytime running lights at iJDMTOY.com.
