Joystick Controlled Servo Using Arduino(with Programming)
Introduction: Joystick Controlled Servo Using Arduino(with Programming)
About: i am an electronics hobbyist.
In this tutorial we will make a joystick control servo using Arduino Uno.Servo will move according to joystick motion.
Teacher Notes
Step 1: Components Required:
  1. Arduino Uno
  2. Joystick
  3. Servo motor
  4. Breadboard
  5. wires
Step 2: Connection:
Connect the all components according to circuit diagram:
  1. Joystick Connection:
    1. joystick VCC --> Arduino 5V
    2. joystick GND --> Arduino GND
    3. joystick x_axis --> Arduino pin A0
  2. Servo Connection:
    1. servo VCC --> Arduino 5V
    2. servo GND --> Arduino GND
    3. Servo data_pins --> Arduino pin 10
Step 3: Programming:
Upload the following program in Arduino Uno board:
#include<Servo.h>
Servo servo;
int x_axis;
int servo_val;
void setup()
pinMode(A0,INPUT);
servo.attach(10);
void loop()
x_axis=analogRead(A0);
servo_val=map(x_axis,0,1023,0,180);
servo.write(servo_val);
Step 4: Source Code:
code :Source code(click here)
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
