KITCHEN BROOM CABINET
295
Yes, I'm brillig, and my slithy toves still gyre and gimble in the wabe. So let me welcome you t...
On my Honey-Do list was to build a broom cabinet in the kitchen. Here's how it turned out. Following is how it was built.
Teacher Notes
Step 1: WE NEEDED a BROOM CABINET IN THE KITCHEN
I had space next to the fridge. I didn't work from plans other than an idea in my head. The height would be the same as the existing and the width would be a couple inches short of the end of the wall.
Step 2: MATERIALS
One 8' 1 x 12, scraps of 3/4" plywood, 1/4" plywood I had laying around, a piece of baseboard from the lumber cart, two sets of hinges and two pulls.
Step 3: TOOLS
Pictured are the tools I used.
Step 4: CUTTING AND ASSEMBLING
The 1 x 12 board would be for the visible side and the joined 3/4" ply for the side against the fridge. The 3/4" ply would also be the dividers and shelves of which there were four. Top and bottom dividers and two shelves. I notched out both the toe kick and baseboard clearance.
Step 5: INSTALLING THE CABINET
I added some nailers and screwed the cabinet to the studs. Then I removed and painted it (three coats) and reinstalled it.
Step 6: UPPER CABINET DOOR
I made a rubbing of the shape of an existing door. I used it to copy the shape onto the top rail. I assembled the rails and stiles and routed the cove and round over profiles to match the existing door. I routed a rabbet in the back and installed a panel of 1/4" ply. I painted it and installed it.
Step 7: LOWER CABINET DOOR
I cut and assemble the lower cabinet door, routed the edges to match the existing, added a 1/4" panel, painted it, put on hinges and a pull and installed the door.
Step 8: BASEBOARD MOLDING
I found a piece of baseboard molding, coped the part that went against the existing molding, mitered the front and cut a mitered sliver to finish off the front edge and caulked it in place.
Step 9: HAPPY WIFE, HAPPY LIFE
Well, one more Honey-Do off my list. Next looks like a small hall table by the entrance door.
Hope you enjoyed this build.
Woodworking Contest
Woodworking Contest
Be the First to Share
    • Furniture Contest
      Furniture Contest
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
