KURT.1 the Articulated Cardboard Robot
2,850
51
About: I studied electronics at school and in the last years I have become passionate about sevel tech subjects: - mechanical desing - Arduino and its IDE - Raspberry Pi + LAMP server and Python - Stepper motors - ...
Hello makers and artists!
As I promised you in the instructable about building a cardboard city, now I am here to introduce you the instructable about building the fantastic Kurt1 robot.
Kurt1 is a fully articulated cardboard robot, invented by my dear friend Emiliano. The robot can be placed in all different poses, it can grab things, it moves its limbs and its arms in an anthropomorphic way. The name etymology is a word pun coming the Italian word for cardboard "cartone" so Kurt-one and then Kurt1.
Kurt1 development took more than 3 months of design and sprouted from its inventor mind because he wanted to create a cardboard toy that was different from the others: he wished it to be "alive"; so building a robot was the perfect choice. Likewise action figures, this cardboard robot had to be articulated and have lots of different poses. The problem was to figure out how to make its limps move only starting from cardboard. Emiliano's great mind realized how he could use cardboard properties at its advantages. We will see this in great details in a special step.
There was a lot of experimentation and study to come out with the final product, I hope that following along with the instructions you manage to make this project alive by yourself.
Kurt1 comes in three different versions:
- KURT.1 (the first and the original one, the one with the grey background in the pictures)
- KURT.1 STEAMPUNK (the one with the red background)
- KURT.1 SAMURAI (which reminds of a cardboard Gundam, the one with the blue background)
DANGER: As always before starting, remember to pay attention while using the cutter!
Teacher Notes
Step 1: Materials Needed: Cardboard Only!
- rigid 2-layer cardboard 6mm thick
- slim 2mm thick cardboard
- glue gun
That's it!! The rest is just creativity.
Step 2: Understanding Cardboard Properties
Before starting to work with cardboard it is important to understand its properties.
Cardboard it is an extremely versatile material because the following things work with it:
- if it is cut lengthwise it is very rigid (↑ arrow up symbol)
- if it is cut widthwise it is less rigid (→ arrow right symbol), but if it is half cut and then marked with a ruler it will bend always along the cut line
Crossing two strips of cardboard, one cut lengthwise and the other widthwise we can make them slide and thus create a joint.
There is a video of a demonstrative cardboard robot where you can see how all the junctures move.
We had prepared instructions on how to build a cardboard robot which are very detailed and you can download them down here. I am sure you will be able to follow along well with the images.
Step 3: Cutting All the Cardboard Strips
You can download the attached PDF, print all the pages and cut the paper strips and use them as template to trace the contour on the cardboard that will have to be cut in strips.
The width of each strip is 20mm and made of 6mm thick cardboard.
Pay attention when cutting the strips, some strips, for example 1, 2, 3, 4, 8 have to be cut lenghtwise ( ↑ arrow up symbol), some other strips, for example 5, 6, 9 have to be cut widthwise (→ arrow right symbol)
The folding points are where there are dashed line. The distance between the dashed line is given in the table below measuring from the bottom of the strips. Have a look at the example of strip 24 to understand the logic to mark properly the cardboard strips.
STRIP NUMBER:
1. 97mm fold at 36mm
2. 132mm fold at 61mm
3. 112mm fold at 56mm
4. 86mm fold at 25mm
5. 111mm fold at 56mm
6. 66mm
7. 157mm fold at 30mm + 20mm + 31mm + 10mm + 41mm + 25mm
8. 71mm fold at 20mm + 26mm + 25mm
9. 274mm fold at 46mm + 25mm + 31mm + 23mm + 25mm + 23mm + 30mm + 25mm + 46mm
10. 137mm fold at 61mm + 15mm + 61mm
11. 284mm fold at 25mm + 20mm +25mm +20mm + 30mm + 36mm +41mm + 46mm + 41mm
12. 122mm fold at 61mm
13. 56mm
14. 203mm fold at 20+20+25+30+30+37+41
15. 102mm fold at 46mm
16. 30mm
17. 127mm fold at 71mm
18. 106mm fold at 61mm
19. 76mm
20. 202mm fold at 41mm + 25mm + 10mm + 25mm + 20mm + 15mm + 10mm + 15mm + 41mm
21. See drawing
22. 72mm
23. It is the same as strip number 11
24. 142mm fold at 51mm + 20mm + 30mm + 41mm
25. 101mm fold at 25mm + 51mm
C2 20mm x 152mm (this is made of slim cardboard, 2mm)
C4 40mm x 152mm (this is made of slim cardboard, 2mm)
Step 4: Building the Leg
You have to build 2 legs which are exactly the same.
As you can see it is important to pay attention that when you place strip 1 onto strip 2 there is no room between them and they form a perfect L.
C4 rectangle made of slim cardboard is responsible for keeping the leg joint in place. Be careful when applying the glue, it has to be placed exactly on the spots shown in the instructions and must not overflow on the moving juncture.
Step 5: Building the Foot
C2 strip of slim cardboard is used to secure and close the foot juncture: the ankle.
Pulling the ankle down will result in the foot hell and tip to move downwards.
Step 6: Joining the Legs Into the Hip
Here we encounter the first torsion cardboard mechanism, which is obtained fixing a bendable cardboard strip (strip 11) to two rigid points (strip 10 and 9).
Step 7: Building the Shoulder
The shoulder is another joint similar to the one we have already made for the waist.
Step 8: Building the Arm
C4 is a slim cardboard rectangular-shaped piece which is placed in a way that, similarly for the leg, will let the cardboard juncture slide up and down.
Step 9: Building the Hand
For the hand there is smart mechanism similar to the one of the food, everything is calculated in a way that when the wrist is pushed ahead it will close the hand, which can grab firmly things such as a pencil or a wand.
Step 10: Building the Head and Torso
The torso is the only piece of thick cardboard that is not in the form of a strip. The torso can be personalized also in another more rounded or more rectangular shape.
If you would like the head to move you can make it as another cardboard juncture like shown in the instructions.
Step 11: Joining All the Pieces
This is the last step to have your cardboard robot fully assembled.
Congratulations for getting here!!
Step 12: Kurt.1 Interchangeable Face
You can add small cadboard details on the robot. We have added a heart because Kurt1 is a robot with feelings!
You can change its face at your liking, we made one with the letter "K" of Kurt as its eyebrows and with rounded curious eyes.
Step 13: Kurt.1 Samurai Version
The samurai version really reminds of a Gundam robot.
To make it you have to start from the basic Kurt1 skeleton and then add as many details as possible made of slim cardboard. Add all sort of wingtips, triangles, fins and vanes. We have also glued some cool futuristic shoulder pads.
Step 14: Kurt.1 Steampunk Version
Steampunk Kurt1 has a different torso and has a crest that gives him the punk look.
Removing the outer cover of cardboard allows the outer cardboard wave to become visible: this technique was used to make Kurt1 Steampunk harms and torso to look cooler and unique.
Step 15: Building KURT.1 Project Complete!
Let me know which Kurt1 version is your favorite :)
Kurt.1 robot series was an Etsy venture that my dear friend Emiliano (on the left in the picture) and me used to run together.
We funded the Etsy shop called Antu Desing Carboardmyth. Unfortunately, we decided to stop for now because the demand for cardboard robots was very timid. If you think that we should get back on business let us know.
I hope you will have fun building your own cardboard robots.
Best wishes makers!!
Bye! Until the next instructable,
Pietro
Cardboard Speed Challenge
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    11 Discussions
    DanPro
    7 weeks ago
    Nicely done! Top 10 for sure.
    danilonsn
    Question 7 weeks ago
    This is so cool, congrats for such amazing work!!!
    May I ask how did you create the graphic manual, with all the poses and pieces? It looks so professional as well...
    1 answer
    Merenel Researchdanilonsn
    Answer 7 weeks ago
    Hi! Thank you! For each instructions' step we made a corresponding 3D model in Blender, there we had applied texture to make the cardboard waves. We carried on with this until we made the actual 3D model of the robot in Blender. After we had all the poses' screenshots we rendered them and used them in Krita and Illustrator to make the actual instructions' page.
    Gadisha
    7 weeks ago
    Wow, this project turned out beautiful!
    And it moves so smoothly.
    Merenel ResearchGadisha
    Reply 7 weeks ago
    Thank you! Yes, incredibly, even after 6 years the cardboard joints of the robot still move very smoothly.
    seamster
    8 weeks ago
    This is a beautifully designed robot, and the photos are gorgeous as well. Well done guys, thank you so much for sharing! : )
    anjin12
    7 weeks ago
    Wonderful instructable. How did you make your illustrations? What program did you use?
    Merenel Researchanjin12
    Reply 7 weeks ago
    Thank you! The illustrations were made starting from a 3D model of the robot in Blender which was arranged differently for every step of the instructions. Then the page was made using Krita or Illustrator.
    snorlaxprime
    7 weeks ago
    Awesome creation, looks cool and I love how it can be articulated
    Merenel Researchsnorlaxprime
    Reply 7 weeks ago
    Thank you! Yes, figuring out how to create joints with cardboard was the most challenging thing.
