Introduction: Keyboard Lighting
Hey.
Today I'm doing a power adjustable keyboard lighting. And the light is not shining in his eyes.
The backlight turns on with your computer and connects to your computer.
Detailed assembly and demonstration work can be seen on the video.
Step 1: The Scheme Is Simple.
Step 2: ​We Need
  • IRF840 transistor
  • 2pcs 22k resistor
  • 240k resistor
  • variable resistor 100k
  • 1-10 uf capacitor 25V
  • LED 35cm white strip
  • steel wire
  • aluminum profile
  • wire
Step 3: Connect Resistors and Solder on the Circuit Transistor.
Step 4: Glue the Transistor to the Radiator and Paste It Into the Body.
Step 5: Check the Work
Step 6: Set the Keyboard Aluminum Profile and Glue in a Convenient Spot Control.
Step 7: Connected to the System Power Supply Unit
Step 8: ​result
see before and after.
Thank you for attention!!!
