Introduction: AVATAR ROBOT
This project uses the Microsoft Kinect for the Xbox 360 and a human biped robot.I used my own 3d Printed Robot to replicate my actions, its combination of Microsoft Kinect SDK, Processing, and Arduino.
Though i controlled arm, if you good at programming, little changes in the code will let you control the entire robot body.....
Thanks to this guy:
https://www.instructables.com/id/Kinect-Controlled-Arms/
Step 1: Things You Need
Hardware things, you can get these from any online store
1. ARDUINO
2.KINECT SENSOR
3.BI-Ped Robot
Software things
you need to have a PC (or) Laptop with Processing Software to run the code
You can find the Respective files in the attachment
1.Arduino Code (.ino extension)
2.Processing code (.pde extension)
3.3d printing files of BI-ped robot (rar extension)
Step 2: Software Guide
First you will need to download the Arduino software:
https://www.arduino.cc/en/Main/Software
Then Processing 2.2.1 (needs to be processing 2, won't work on processing 3):
https://processing.org/download/?processing
Next is the Microsoft Kinect SDK (this contains the drivers you need to operate the Kinect):
https://www.microsoft.com/en-us/download/details.a...
Following that,
you will need to download the Simple Open NI library (1.9.6)
Step 3: Running the Code
- 1.open Arduino IDE upload the .ino codeto your arduino board, attach servos according to your code
rightshoulder . attach ( 9 ); //right shoulder servo pin to arduino pin 9
rightelbow . attach ( 10 );
leftshoulder . attach ( 11 );
leftelbow . attach ( 12 );
find out these lines in the code and make any-changes you want or you can leave it as it was....
2.Now run your Processing Code:
find the below line in your .pde code
String portName = Serial.list()[0];
replace the line change this line " String portName = Serial.list()[0]; " to your available port numbers, lets say you have two COM Ports then "String portName = Serial.list()[1];, if you have three then "String portName = Serial.list()[2];" all the best, you can find the list of com ports in your pc --> my computer-->right click-->device manager---> explore ports then identify the number of com ports
If everything is fine then you can see a window like in this step itself::::::::
Thanks to this guy:
That's it, now you can control the robot with your actions: (if you like the video please share and comment)
