Kintsugi Wooden Earrings / Japanese Art
650
25
Introduction: Kintsugi Wooden Earrings / Japanese Art
An attempt to create a pair of earrings with a very popular Japanese technique kintsugi.
"Kintsugi (金継ぎ, "golden joinery"), also known as Kintsukuroi (金繕い, "golden repair"), is the Japanese art of repairing broken pottery by mending the areas of breakage with lacquer dusted or mixed with powdered gold, silver, or platinum, a method similar to the maki-e technique. As a philosophy, it treats breakage and repair as part of the history of an object, rather than something to disguise."
Teacher Notes
Step 1: Basic Material
For the body of earrings I chose an exotic wood with dark tones such as the wenge. It will give a nice contrast with the golden joinery. After I cut the plank in the dimensions I wanted, I passed it with sandpaper to have a smooth surface.
Step 2: Cut the Shape
From the previous wood sheet I cut two circles! You can use a saw hole or a handsaw for the cutting. After passing with sandpaper are ready for the next step!
Step 3: The "breakage"
To build the key element of this project that is the brake in the wood. I just made a crack shape in Inkscape, then I covered the wood with masking tape and with the use of a laser cutter I etched the image on the wood.
Step 4: The Golden Repair
For "repairing" the broken wooden earrings I use a mixture of epoxy glue and golden metallic paint, which I applied to the the areas of breakage with a toothpick. After waiting for the glue to dry, I removed the masking tape.
Step 5: The Result !
I find the result quite interesting. If you find it too, you can visit my shop to see more details about this pair of earrings and some other interesting creations!
You can click here for my shop!
Fashion Contest
Fashion Contest
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    3 Discussions
    danialsa
    danialsa
    27 days ago
    easy process and they look cool \m/
    Alex in NZ
    Alex in NZ
    7 weeks ago
    A great technique giving a beautiful result. Thank you for sharing your work and good luck in the competition :-)
    illustrisWorkshop
    illustrisWorkshop
    Reply 7 weeks ago
    Thank you, I really appreciate it!
